Thread: ABS and Traction control light on dash help
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: ABS and Traction control light on dash help
    Dec 2016
    Glasgow
    Interestingly it was below freezing today and the lights were off on my dash ! I have bought a new ABS sensor still though to change.
  2. Re: ABS and Traction control light on dash help
    Dec 2016
    Glasgow
    I replaced the ABS sensor, it was a pig of a job and took me 5 hours !
    The sensor its self was well and trully stuck and corroded in place. I had to drill it out along with the bolt. I needed to remove the caliper and disk to get into the sensor properly to allow me to drill it which took me about 2.5 hours.
    Then the worst part was trying to find the damn plug connector for the other end of the sensor in the car, I know it was behind the rear panle (my car is a cabriolet) however I just couldn't find it and in the end had to remove the rear seat and trim completely eventually finding it buried and cable tied at the back. The next challange was to feed the new cable through from the underside which involved removing a bottom panel then using a piece of metal wire to locate and pull through.
    Once all done I then had to put the car all back together which if anyone has a cabriolet may know how tricky the rear panel can be !
    End result is that the problem has been fixed, although I did strip a wheel bolt when I put the wheel back on !
  3. Re: ABS and Traction control light on dash help
    Had the same problem pre MOT, rear sensor, a bit of a bitch apparently, garage had to get rear seat out, not good!
  4. Re: ABS and Traction control light on dash help
    Dec 2016
    Glasgow
    Im glad it is not just me then ! Can I ask how much the garage charged?
  5. Re: ABS and Traction control light on dash help
    Jun 2009
    uk
    garage replaced my rear left sensor today abs esp light was off when i drive for a couple of minutes comes back on again its intermittent now.
  6. Re: ABS and Traction control light on dash help
    1837 Post(s)
    We need to know more than that, I suggest you start your own thread Tab.
  7. Re: ABS and Traction control light on dash help
    #17
    Dec 2016
    Glasgow
    Sorry, meant to post that I have now fixed this.
    It was the rear right abs sensor. I had to drill out the old one as it was corroded and tap a new thread for the new sensor. The hardest part was getting to the plug, I had to remove the whole back seat and side panel and eventually found it buried inside a wiring loom.
  1. DTC 04642 under ABS with both ABS and traction control dash lights on.
    By oldandbald in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-06-2015, 04:17 PM
  2. Please Help Traction light on in Dash
    By wmccann in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-01-2015, 12:42 PM
  3. traction control dash light is on
    By Tonka in forum Beetle 2000-
    Last Post: 05-04-2010, 02:04 PM
  4. traction control dash indicator
    By nfegan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-07-2007, 09:59 AM
