Thread: Golf mk5 GT TDI 2L Throttle body and coolant warning.
  1. Golf mk5 GT TDI 2L Throttle body and coolant warning.
    Nov 2017
    west sussex
    Hi. New member here, very grateful for all the previous posts, regarding similar issues people have been having.
    However, just a few quick questions, EML has been on for 12 months or so, no issues with driveabilty or loss of power, just a poor idle and loud shutdown. After searching for possible problems, realised it was the issue regarding throttle body/IMF. Fuse 24 has blown, replaced, and blown again. Want to carry out the work myself, not a mechanic, but very hands on especially with the use of Google and YouTube.
    Only issue I have, is obviously all car models are laid out differently in the engine bay, I can't seem to 100% locate the area of the throttle body, I have an idea of location, if I post a picture, could someone point me in the right direction.....
    Also, main dealer have quoted me £450 for throttle body, I've seen on ECP that it is at least half that price, any reason why? Apart from not being a VW genuine part? Just wondering if the ECP item doesn't come with another part of the system.
    Also, everytime I start engine, and drive off, the STOP check coolant warning comes on...... rectified by switching off, re-starting and it clears, this happens everytime I start the car, but has got worse recently with the colder weather. I have checked the fluid and levels, all fine. I assume it's a sensor issue, and I'm picking a part up from main dealer tomorrow, which is a new tank and sensor for £23. Has anyone had this problem before and doing this fixed the issue?
  2. Re: Golf mk5 GT TDI 2L Throttle body and coolant warning.
    1840 Post(s)
    The V157 is where you indicate, after the boost hose and before the EGR valve. There are pattern and OE aftermarket V157 valves, VDO made the originals.
  3. Re: Golf mk5 GT TDI 2L Throttle body and coolant warning.
    Oct 2017
    you're in the right direction about throttle body and I have had the problem with coolant level sensor
  4. Re: Golf mk5 GT TDI 2L Throttle body and coolant warning.
    Nov 2017
    west sussex
    Did you manage to sort out the coolant issue? Hoping a new tank and sensor will sort it, so irritating having to turn engine off and on again, only ever used to have to do it once, now it's 3 times at least.
  5. Re: Golf mk5 GT TDI 2L Throttle body and coolant warning.
    Nov 2017
    west sussex
    Excellent, at least I'm in the right area. Thank you.
  1. Question Mk4 golf 1.6 throttle body issues
    By thebiz2222 in forum Audi VW Specialist Centre
    Last Post: 15-09-2016, 09:43 PM
  2. Clean throttle body and perfom Throttle Body Alignment (TBA) - big job?
    By allanmb in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-01-2013, 09:50 PM
  3. Throttle Body Alignment on Golf GTI (2E)
    By ctwomey in forum VCDS - General Questions
    Last Post: 27-04-2009, 10:24 PM
  4. Golf MK4 Throttle body allignement.
    By stupotads in forum VCDS - General Questions
    Last Post: 17-10-2008, 11:39 AM
  5. Golf Mk3 Throttle body
    By Slim in forum Golf MK3 - 1993 - 1999
    Last Post: 23-08-2007, 10:34 PM
