Thread: Audi A4 B6 no vents flaps working
Results 1 to 10 of 11
  1. Audi A4 B6 no vents flaps working
    Jan 2012
    Dublin, Ireland
    Hi there,
    I've just noticed that I can't alter any of the vent directional settings on the car. Things have stuck open on dash (side) vents only. It wouldn't worry me bar for the fact that windscreen demisting isn't operable and with cold weather, I'm starting to need it.
    The fan is working okay and all the buttons are lighting up as usual when pressed. Just no actual activity from the vent directional flaps in response to the button pressing.
    I checked the fuses and popped the control unit out to see if a plug had fallen out the back of it but nothing amiss there.
    Any ideas?
  2. Re: Audi A4 B6 no vents flaps working
    Southern County Softy
    20 Post(s)
    Quote Originally Posted by iano View Post
    Hi there,
    Any ideas?
    Scan with VCDS for faults.
    Reset flap motors in basic settings.
    The flap motors are known to jam, they can be taken out then opened up and lube the worm drive.
    There are "how to" on here, try a search.
    A4 2.5 tdi QS (mapped)
  3. Re: Audi A4 B6 no vents flaps working
    Jan 2012
    Dublin, Ireland
    Quote Originally Posted by kite View Post
    Thanks kite. Is there a number of motors? In which case I wondering why they'd all give up at the same time - none of the buttons (window / dash / floor / intense front demisting) do anything. I'd imagine a number of motors which would permit flow through a number of outlets.
  4. Re: Audi A4 B6 no vents flaps working
    20 Post(s)
    There are a few motors, first scan for faults then reset flap motors using VCDS.
  5. Re: Audi A4 B6 no vents flaps working
    Jan 2012
    Dublin, Ireland
    Will do. Thanks.
  6. Re: Audi A4 B6 no vents flaps working
    Nov 2015
    West Yorkshire
    As a temporary fix you could just disconnect the de mister flap actuator and manually put into the open position until you have time to properly investigate the problem.
  7. Re: Audi A4 B6 no vents flaps working
    Nov 2015
    West Yorkshire
    [QUOTE=germanwhip81;1075122]As a temporary fix you could just disconnect the de mister flap actuator and manually put into the open position until you have time to properly investigate the problem.[/QUOTE
    Remove the glovebox (5 m8 hex bolts) and there are the motors.
  8. Re: Audi A4 B6 no vents flaps working
    Jan 2012
    Dublin, Ireland
    Quote Originally Posted by germanwhip81 View Post
    I gather that's just a matter of whipping the glove box out? Makes sense to do that and leave until next I've a reason to head to the garage. I see a long finger coming on
  9. Re: Audi A4 B6 no vents flaps working
    Nov 2015
    West Yorkshire
    What, like E.T?
  10. Re: Audi A4 B6 no vents flaps working
    Jan 2012
    Dublin, Ireland
    More Michaelangelo...
  1. No hot air, most of the time. All vents, controls working, in and out hot.
    By mwilson in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-12-2016, 12:39 PM
  2. Question heating not working and no air circulating out of the vents
    By bigjazzie in forum In Car Entertainment
    Last Post: 30-03-2015, 10:12 PM
  3. Audi A6 Avant SE 177 SE 6Sp Manual 2012 Mud Flaps C7
    By burningoil in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 13-05-2014, 04:33 PM
  4. Replies: 1
    Last Post: 18-01-2012, 10:48 PM
  5. air vents not working- streo fitted related?
    By stringman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-11-2008, 11:11 AM
