Thread: Continuous turn signal.... electrical signal
  1. Continuous turn signal.... electrical signal
    Nov 2017
    Madrid, Spain
    Hello, Gentlemen (and Ladies, if any present),
    I come to you in somewhat of a despair. This is an issue I've been wracking my brain for a long time now... and to some of you it may seem quite obvious... and I surrender to your superior wisdom and experience.
    I need a continuous electrical signal indicating if and which turn signal is connected. So, two wires: one hot when left turn signal is on; the other hot when the right turn signal is on; both cold when no turn signal activity.
    I've come to the logical conclusion that the best place to get such a signal is somewhere between the turn signal switch behind the steering wheel (to get to the connector, one must take the steering wheel pretty much completely off... and I just don't dare). It was suggested to me to get it from the turn signal relay, but I have no clue where this relay is located, nor which pins on it carry the signal I need. Also, not quite sure if at the relay I'm going to find a continuous or discontinuous electrical signal.
    Anyhow, I would be so EXTREMELY grateful for any info at all you can share with me... and I'll name my first-born after you. Ok, so first I have to find someone that can stand me for longer than 24 hours, but hey! Everything possible...
    Kindest regards from a Spaniard in despair.
  2. Re: Continuous turn signal.... electrical signal
    Nov 2017
    Scotland
    25 Post(s)
    you could try this site prob find exactly what your after---http://workshop-manuals.com
  1. Turn Signal Change
    By dan2485 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-02-2016, 09:34 AM
  2. Turn signal/indicator for DRL?
    By Mic_g in forum Passat CC
    Last Post: 11-07-2015, 10:05 PM
  3. Turn signal problem???
    By knight A4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-02-2009, 09:38 PM
  4. Turn signal problem
    By a6rob in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-04-2008, 04:52 PM
  5. Front Right Turn Signal
    By randyrich86 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-03-2008, 11:05 AM
