Thread: Vcds
Results 1 to 8 of 8
  1. Vcds
    Jul 2017
    Blackpool, England
    Hi, just bought a VCDS, when I bought the car 10 mths ago it had no history, so I connected the VCDS to the car and run a total scan, ended up with 5 fault found.
    Now, can I erase them because they might have being sorted, and if they haven't the fault will appear again, thanks.
  2. Re: Vcds
    Nov 2017
    Scotland
    25 Post(s)
    yes thats rite--but do a full scan( auto scan-it will scan all modules !) and save the scan, that way you will have all coding and any workshop codes that have been put in--just incase you ever need them !!!!
  3. Re: Vcds
    1837 Post(s)
    Occasionally erasing the codes can upset systems, it is rare but most prevalent on late model petrol engines where the engine has adjusted itself to work around the codes and deleting them send it crazy. We had this a few months ago on an RS4 V8 where when we cleared the codes stored that were making the light come on, the engine went nuts and ran like a pig until it sorted itself out again by compensating for the problems.
  4. Re: Vcds
    Nov 2017
    Scotland
    25 Post(s)
    that was why I was saying to full scan and save the scan--then he have all coding in all modules and any workshop codes that had been put in !!!
  5. Re: Vcds
    1837 Post(s)
    We overlapped each other there, you posted a minute or so before me. IF they go whappy no amount of preparation or code recording will help, they just do it but as I said, it's very rare.
  6. Re: Vcds
    Nov 2017
    Scotland
    25 Post(s)
    thanks for the heads up on that one--not come across it ,to date !!!
  7. Re: Vcds
    Jul 2017
    Blackpool, England
    well I thank you both, I hope it doesn't, it was an auto scan that I did...
  8. Re: Vcds
    Jul 2017
    Blackpool, England
    and yes I did save it.
  1. advice on buying VCDS/VCDS-lite
    By borakev in forum VCDS - General Questions
    Last Post: 16-04-2019, 05:20 PM
  2. where to buy VCDS
    By Anchco in forum VCDS - General Questions
    Last Post: 22-04-2016, 01:37 PM
  3. Which VCDS do I need
    By peter goble in forum VCDS - General Questions
    Last Post: 03-05-2014, 05:46 PM
  4. Why should I buy VCDS?
    By darich in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-03-2012, 11:38 PM
  5. Question vcds
    By peterpaulogrady in forum Polo - Derby - Lupo - Fox
    Last Post: 16-04-2011, 02:52 PM
