Thread: unstoppable fan draining battery on Caravelle t5 130hp 2008 lhd
  1. unstoppable fan draining battery on Caravelle t5 130hp 2008 lhd
    Nov 2017
    norway
    Hi guys, First post as noobie.
    Have a t5 Caravelle 2008 tdi, 130hp, that has 160,000km (100,000 miles) on the clock.
    During the winter months with temperatures below zero a fan in the engine bay area
    refuses to turn off after the ignition is turned off and the key is removed.
    In the morning of course the battery is flat.
    Have had the van into VW workshop several times but still no joy.
    They have changed sensors and the problem seemingly disappeared
    but after a few weeks returned.
    Can anyone come with suggestions I can present to VW to get them
    thinking out of the box?
    Thanks in advance, graybeard
  2. Re: unstoppable fan draining battery on Caravelle t5 130hp 2008 lhd
    Jan 2016
    Wiltshire
    Sounds like the auxiliary water pump running on due to the auxiliary coolant heater running to help the engine reach normal operating temperature - usually this happens at temps below 5C. Do you know which sensors have been changed? I believe there are a few related to coolant temperature. One will be responsible for stopping the pump.
  1. Something draining my battery?
    By Quatrelle in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-04-2017, 09:07 PM
  2. 97 A6 draining battery
    By hootonm in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 18-08-2010, 09:03 PM
  3. draining battery
    By coyotee in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 25-09-2009, 04:54 PM
  4. Please Help Battery draining
    By medman in forum Golf MK3 - 1993 - 1999
    Last Post: 23-06-2009, 09:57 AM
  5. battery draining
    By catpassat82 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-02-2008, 10:52 AM
