Thread: Power Steering gone G85 toasted?
Results 1 to 10 of 10
  1. Power Steering gone G85 toasted?
    Nov 2017
    Warrington
    Hello and hope you can help, I have recently changed the battery on the Mrs Golf since then the power steering light has been on. I have attempted to reconfig the power steering but seems to be stuck in ABS test mode. Also Steering measuring blocks angle shows 0 all the time.
    What else can i try Thanks
    Gareth?
    VAG Is showing
    44-Steering Assist -- Status: Malfunction 0010
    2 Faults Found:
    01486 - System Function Test Activated
    000 - -
    00778 - Steering Angle Sensor (G85)
    005 - No or Incorrect Basic Setting / Adaptation
    2 Faults Found:
    02546 - Steering Limit Stop
    Freeze Frame:
    Mileage: 154240 km
    Temperature: 32.0°C
    Voltage: 12.20 V
    Voltage: 12.00 V
    000 - -
    Freeze Frame:
  2. Re: Power Steering gone G85 toasted?
    Dec 2014
    Bedford
    42 Post(s)
    Quote Originally Posted by RhinoHammer View Post
    Gareth?
    VAG Is showing
    2 Faults Found:
    000 - -
    2 Faults Found:
    Freeze Frame:
    Mileage: 154240 km
    Temperature: 32.0°C
    Voltage: 12.20 V
    Voltage: 12.00 V
    000 - -
    Freeze Frame:
    Have you fully turned the steering wheel to the right held it there then fully turned it to the left held it there then centered the steering and driven in the straight ahead position upto 30mph?
  3. Re: Power Steering gone G85 toasted?
    Nov 2017
    Scotland
    25 Post(s)
    it can take a few miles before it resets itself--but basic setting has to be done first, then just drive !!
  4. Re: Power Steering gone G85 toasted?
    Nov 2017
    Scotland
    25 Post(s)
    Gareth?
    VAG Is showing
    2 Faults Found:
    000 - -
    2 Faults Found:
    Freeze Frame:
    Mileage: 154240 km
    Temperature: 32.0°C
    Voltage: 12.20 V
    Voltage: 12.00 V
    000 - -
    Freeze Frame:
    looks like you are still in system function test mod--do basic setting then drive and wheel light should just clear itself, it could take a few miles-just done this on A3 8p other day
  5. Re: Power Steering gone G85 toasted?
    Jan 2009
    Birmingham
    35 Post(s)
    Instructions for the 01486 system function test
    • Firmly press the Brake Pedal until a certain Brake Pressure (usually right above 30 bar) is reached.
    • Brake Pressure Sensor (G201) Plausibility will be confirmed by a Change in the Brake Electronics Warning Lights.
      • On Bosch, the ASR/ESP Warning Light (K155) will switch OFF and the ABS Warning Light (K47) will switch ON.
      • On Continental/Teves, the ABS Warning Light (K47) will switch OFF and the ASR/ESP Warning Light (K155) switch ON.
    • Start Driving straight with a steady Speed of ~20 km/h (~13 mph).
    • Turn the Steering Wheel either Left or Right between a 90° Angle (1/4 Turn) to 180° Angle (1/2 Turn) and keep it steady.
    • Lateral Acceleration Sensor (G200) and Rotation Rate Sensor (G202) Plausibility is confirmed
      once the remaining Brake Electronics Warning Light(s) switch OFF.
    • The Function Test is now completed
    Perform
    Steering Limit Stop Adaptation THIS IS FOR THE STEERING WHEEL 02456 CODE
    • Make sure the Ignition is ON and the Engine is Running.
    • Center Steering Wheel (±10°) and hold it centered for about 5 Seconds.
    • Turn Steering Wheel completely to the Left and hold there for about 10 Seconds.
    • Turn Steering Wheel completely to the Right and hold there for about 10 Seconds.
    • Center Steering Wheel (±10°).
    • Switch Engine and Ignition OFF.
    • Switch Ignition ON.
    • Wait about 5 Seconds.
    • Steering Assist Warning Lamp should turn OFF (If it doesn't, perform a short Test Drive).
  6. Re: Power Steering gone G85 toasted?
    Nov 2017
    Warrington
    Thanks for the suggestions I will attempt them again all though think I think the steering angle sensor my be faulty as it is not returning any angle info which could be why it's not clearing from the test function or the steering limit stop error.
    i have srappy G85 orderd from fleebay so will swap if still not getting resolved
  7. Re: Power Steering gone G85 toasted?
    Nov 2017
    Scotland
    25 Post(s)
    is it coded in properly ??? vagcom will walk you through the procedure
  8. Re: Power Steering gone G85 toasted?
    Nov 2017
    Warrington
    Still cant get this working, swapped G85 still zero in Steering angle measuring blocks and following error for adjustment???
  9. Re: Power Steering gone G85 toasted?
    Nov 2017
    Scotland
    25 Post(s)
    have a look here if you haven't already--http://wiki.ross-tech.com/wiki/index.php/00778--depending on what abs module is fitted you might want to also look here--http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Brake_Electronics_(MK70). hope it helps !!
  10. Re: Power Steering gone G85 toasted?
    1836 Post(s)
    You have activated the test function, now you MUST finish it or you cannot delete the code. I have had a few where it is impossible to get the setup finished using VCDS and I had to use the dealer system ODIS. I have a Golf 5 in now, an R32, that I had this with last year where I could not get the light out but at that point I had just got myself set up with ODIS and going through Guided Fault Finding had the light off in a few minutes. The trouble is hardly any independents have ODIS, it is just main dealers.
  1. Question Toasted BOSE Amp
    By Tay in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-07-2015, 03:20 PM
  2. Power Steering Fluid leak near steering column
    By simagain in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-08-2013, 05:19 PM
  3. Please Help 6N1 Polo leak in power steering pipe from pump to steering rack
    By crauch6 in forum Polo - Derby - Lupo - Fox
    Last Post: 18-02-2012, 08:36 AM
  4. Have I Toasted clutch after remap?
    By fasttdi in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-05-2009, 01:23 AM
  5. power steering oil
    By mbu10 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-07-2008, 08:18 AM
