Thread: 16485 Mass Air Flow Sensor (G70)
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: 16485 Mass Air Flow Sensor (G70)
    #11
    Dec 2014
    7 Post(s)
    Ah ok, Cheers they sound like some top tips. Will try and have a look at doing those one evening.
    Sent from my XT1039 using Tapatalk
  2. Re: 16485 Mass Air Flow Sensor (G70)
    #12
    Nov 2017
    Scotland
    25 Post(s)
    Quote Originally Posted by ianlovatt View Post
    Thanks for the replies. Buried in my essay above i've already found the Ross tech page and seen the suggestions. I think Niall's comment on the air filter cover might be best lead if it errors again. It has just had a service (fuel and air filters). As the fault has gone intermittent I guess that means the MAF readings have been ok for a period of time?
    Anyways garage weren't overly interested when I turned up today with no warning light on, they did read the codes out and found the same (16485 intermittent). They said it could even be the sensor getting used to being able to breath again after the new air filter? If there is some long self calibration period maybe that's why it was cross at first but hasn't reported any 'implausible' readings since?
    Ian
    just do an ECU reset yourself with Vagcom, it might just end all your probs-all it do's is reset all back to factory defaults-then the car starts to learn how it is being driven and starts ajusting as it needs to !!
  3. Re: 16485 Mass Air Flow Sensor (G70)
    #13
    Dec 2014
    7 Post(s)
    Thanks vagnuts didnt realise there was a reset option like that. Think I'll poke around with the mechanical suggestions first and if that's all in order but then the fault comes back to haunt us I'll give that reset a go.
  4. Re: 16485 Mass Air Flow Sensor (G70)
    #14
    Jan 2009
    Birmingham
    17 Post(s)
    Vagnuts How do you do a ecu reset with Vcds?
  5. Re: 16485 Mass Air Flow Sensor (G70)
    #15
    Nov 2017
    Scotland
    25 Post(s)
    re-ECU reset 01 engine- addaptation-10- chanel 00-read- then just save 00--it just resets to factory defaults (I do this reset every month-car feels like new even tho it has done 240.000miles !!) its what the ********hips do when they service the cars themselfs!!- the other thing I would do is take maff of and clean-ie-spray with brake cleaner as they do/can get dirty even tho air go's through filter first !! done this on quite a few and prob solved !! I dont know how to up load photos on here-as I just went out and took pics on the process, if you want to give email I will send them to you !!!
  6. Re: 16485 Mass Air Flow Sensor (G70)
    #16
    Nov 2017
    Scotland
    25 Post(s)
    Quote Originally Posted by arman123 View Post
  1. Please Help Mass air flow sensor
    By michaelhare in forum VCDS - Help Requests
    Last Post: 22-04-2016, 01:55 PM
  2. Please Help Mass Air Flow sensor help?
    By giggsy07 in forum Golf MK4 - 1999 - 2004
    Last Post: 30-03-2010, 05:46 PM
  3. Mass Air Flow Sensor
    By ASR81 in forum Golf MK3 - 1993 - 1999
    Last Post: 28-08-2008, 03:13 PM
  4. mass air flow sensor
    By Jak68 in forum Golf MK4 - 1999 - 2004
    Last Post: 02-04-2008, 12:23 PM
  5. Mass Air Flow Sensor
    By tigre64 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-10-2007, 04:32 PM
