Thread: 2.5tdi starting problem
Results 1 to 10 of 17
  1. 2.5tdi starting problem
    Nov 2017
    Inverness
    Looking for some help with my a4 2.5tdi. Am having problems starting it, turns over ok but doesn’t fire at all. If you try it a few times it will fire up and runs perfect once started. Will do it when the engines hot or cold.
    Have checked for air bubbles in the clear pipe but it’s ok. Getting rpm signal Also checked the glow plugs all working fine too.
    I suspect there’s a problem with the control unit on the high pressure pump. But anything else worth looking at first?
    Thanks Michael.
  2. Re: 2.5tdi starting problem
    Nov 2017
    Inverness
    Had vag com on it today and got this fault code 00546. Any help would be appreciated.
    Thanks Michael
  3. Re: 2.5tdi starting problem
    Nov 2017
    Scotland
    25 Post(s)
    that code is Immobilizer Control Module (J362)
  4. Re: 2.5tdi starting problem
    Feb 2009
    Ireland
    Does the key symbol flash on the dash when this happens? Also does the engine try to start and die almost immediately? If it does then it indicates an immobiliser problem and it could be the key. If you have a spare you could try that as the module in the key could be the issue. Mine certainly did that occasionally and if you left it for maybe 10 seconds or so and tried again it would often start first time. If its just hard to start generally it could be the pump timing which is out. The 2.5 engines need to have the pump timing set accurately as if it is out it can cause starting issues.
  5. Re: 2.5tdi starting problem
    Nov 2017
    Scotland
    25 Post(s)
    or the fuel lines might need replacing-we got an a6 2.5tdi V6 hard to start turning turning turnin over then bam away it went-turns out the fuel lines were we bit worn so alowing fuel to run back to tank and with no intank pump, it only lifted fuel when cranking-so crank crank crank then start -just a thought !!
  6. Re: 2.5tdi starting problem
    Nov 2017
    Inverness
    No, key light doesn’t flash when it’s not starting. Sometimes it will cough trying to start but generally just turns over. Normally let it turn over for around 5 seconds then try again. Always starts normally on 4th or 5th time. Was just doing it when cold but now if left for 20 30mins won’t start. Will check the return pipes
  7. Re: 2.5tdi starting problem
    Nov 2017
    Scotland
    25 Post(s)
    it do's sound like fuel returning back to tank, and from what you say--its just got worse !!!
  8. Re: 2.5tdi starting problem
    Nov 2017
    Scotland
    25 Post(s)
    just another thought-- blow-pressure the feed pipe back into tank-if any wee pin hole it will show, cause normaly its sucking so if it just a wee pin hole may not be dripping, return pipe is pressured back to tank-so you would see if that was the prob, but sounds like feed pipe to me !!!
  9. Re: 2.5tdi starting problem
    Nov 2017
    Scotland
    25 Post(s)
    have you got vagcom ?? scan might/should show any pos fault !!
  10. Re: 2.5tdi starting problem
    Nov 2017
    Scotland
    25 Post(s)
    yeh scratch my last post--you already scanned it.
  1. Please Help 2.5TDi sudden rough running, vibration, no power, poor starting then no starting :-(
    By andrew shepherd in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-09-2018, 05:31 PM
  2. Please Help 2.5TDI Glow Plug/Starting Problem
    By Zinraf in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-11-2017, 07:50 PM
  3. Warm starting problem 2.5TDI
    By mikeybutch in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-07-2010, 10:14 PM
  4. t5 2.5tDi 2004 starting problem
    By pelerin in forum The Commercial Range
    Last Post: 26-09-2009, 10:55 AM
  5. 01 A4 2.5tdi Problem Starting
    By whoop whoop in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-02-2009, 01:06 AM
