Thread: Golf mk5 2.0tdi loosing coolant but there is no leak??
  1. Golf mk5 2.0tdi loosing coolant but there is no leak??
    Nov 2017
    doncaster
    I started my golf today and the coolant level light came on, when i checked it, it was low however i know it was topped up to the max level only three days prior. The car then began smoking for about five miles after i topped the coolant up, it has now stopped smoking but is still using water, any advice????
  2. Re: Golf mk5 2.0tdi loosing coolant but there is no leak??
    Jan 2009
    Birmingham
    35 Post(s)
    what colour was the smoke?
  3. Re: Golf mk5 2.0tdi loosing coolant but there is no leak??
    Oct 2017
    if no external leaks, most probably the head gasket is on its way out
  4. Re: Golf mk5 2.0tdi loosing coolant but there is no leak??
    Nov 2017
    Scotland
    25 Post(s)
    if it has a water cooled EGR bypas it as I have seen A lot of these fail repetedly, as in loads of them, just take it out and run a hose from outlet to return, I bet that head gasket is not on its way out. if thogh egr is not water cooled-it might be head gasket !!!
  5. Re: Golf mk5 2.0tdi loosing coolant but there is no leak??
    Jan 2013
    bridgend, south wales
    Have you checked the dipstick for signs of water in oil? There will be a sweet smell to it if antifreeze is working it’s way into the engine oil.
    I’ve just had a similar problem on mine which turned out to be the water pump and leaks here are hard to spot
  6. Re: Golf mk5 2.0tdi loosing coolant but there is no leak??
    Jul 2007
    glasgow
    35 Post(s)
    EGR cooler
  7. Re: Golf mk5 2.0tdi loosing coolant but there is no leak??
    Nov 2017
    Scotland
    25 Post(s)
    Quote Originally Posted by niall campbell View Post
    EGR cooler
    I agree as I'v said above, I'v lost count of how many water cooled EGR's even new, within weeks of fitting, start to leak again causing coolant loss-- mostly on a4 b7's though, but yeah they are a week spot across the board-I/we just take them off and blank egr then run pipes from /to--feed to return--problem solved !!!
  1. Loosing coolant
    By stephenwhite990 in forum Golf MK4 - 1999 - 2004
    Last Post: 05-01-2018, 08:03 AM
  2. golf vr6 coolant leak please help
    By probert993 in forum Golf MK3 - 1993 - 1999
    Last Post: 09-07-2010, 09:31 PM
  3. Loosing Coolant
    By karachi_kops in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-11-2009, 07:49 PM
  4. A6 Loosing Coolant
    By Lynlea in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-10-2009, 11:25 AM
  5. Question audi 2.0tdi.loosing coolant
    By atmos in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 30-03-2009, 09:16 PM
