Thread: optical parking on rns510
Results 1 to 1 of 1
  1. optical parking on rns510
    essex
    Hi, I have rear parking sensors fitted from standard and have upgraded to rns510 from rcd500, can I get the optical display of the parking sensors on the rns?? if so, how?
    thanks
    Thursday,09,November,2017,17:07:32:51006
    VCDS Version: 17.8.0.1 (x64)
    Data version: 20170721 DS276.2
    Ross-Tech: Home
    VIN: WVGZZZ1TZ8W091167 License Plate: R70DUR
    Mileage: 144940km-90061mi-09112017 Repair Order:
    Chassis Type: 1T (1K0)
    Scan: 01 02 03 08 09 10 15 16 17 18 19 25 37 42 44 46 52 56 62 72
    VIN: WVGZZZ1TZ8W091167 Mileage: 144940km-90061miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    18-Aux. Heat -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.clb
    Part No SW: 03G 906 021 MP HW: 03G 906 021 AN
    Component: R4 2,0L EDC G000AG 1322
    Revision: --H07--- Serial number: VWX7Z0G93NP1UQ
    Coding: 0000078
    Shop #: WSC 01324 785 00200
    VCID: 79F9D8FB301E6C8ECD-802C
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 02E-927-770.clb
    Part No SW: 02E 300 050 E HW: 02E 927 770 AE
    Component: GSG DSG 081 1402
    Revision: 04608010 Serial number: 00000709260539
    Coding: 0000020
    VCID: 1427894F37BCB1E63E-8040
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0023238
    VCID: 73E5EAD3127216DE87-8026
    Address 08: Auto HVAC Labels: 1K0-907-044.lbl
    Part No SW: 1K0 907 044 CF HW: 1K0 907 044 CF
    Component: ClimatronicPQ35 130 1212
    Revision: 00130022 Serial number: 00000000000000
    Shop #: WSC 131071 1023 2097151
    VCID: 6DD1FCAB7456C02E51-8038
    2 Faults Found:
    00716 - Air recirculation Flap Positioning Motor (V113)
    000 - - - Intermittent
    01592 - Air Quality Sensor (G238)
    014 - Defective
    Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
    Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
    Component: Bordnetz-SG H54 2202
    Revision: 00H54000 Serial number: 00000007802395
    Coding: 01890F2100040F0047120C000000000000097F075C00010000 0000000000
    VCID: 71E9E0DB686E24CE75-8024
    Subsystem 1 - Part No: 2K2 955 119 C Labels: 1KX-955-119.CLB
    Component: Wischer 181007 021 0501
    Coding: 00038805
    Shop #: WSC 01324
    Address 10: Park/Steer Assist (J446) Labels:. 1K0-919-475.clb
    Part No SW: 1K0 919 475 HW: 1K0 919 475
    Component: PARKHILFE 005 1104
    Revision: 00005000 Serial number: 0 263 004 193
    Coding: 100101
    VCID: 6FEDE6A3BE5A323E63-803A
    Address 15: Airbags Labels: 1T0-909-605.lbl
    Part No SW: 1T0 909 605 D HW: 1T0 909 605 D
    Component: 04 AIRBAG VW8 021 0100
    Revision: 02021000 Serial number: 003B9D06PZ5L
    Coding: 0012340
    VCID: 366313C7418043F660-8062
    Subsystem 1 - Serial number: 6332QSME43391A016
    Subsystem 2 - Serial number: 6342QSME4334353FG
    Subsystem 3 - Serial number: 6352QSME3F66497D/
    Subsystem 4 - Serial number: 6362QSME3F77134DV
    Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
    Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
    Component: J0527 056 0111
    Coding: 0001634
    Shop #: WSC 131071 102 209715
    VCID: 7AFBC7F735186796C4-802E
    Subsystem 1 - Part No: 3C8 959 537 D Labels: 3C8-959-537.CLB
    Component: E221__MFL-TK6 H07 0022
    Coding: 00000227
    Shop #: WSC 00000
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No SW: 1T0 920 974 A HW: 1T0 920 974 A
    Component: KOMBIINSTRUMENT VDD 1216
    Revision: V0002000 Serial number: VWX7Z0G93NP1UQ
    Coding: 0003401
    Shop #: WSC 00445 210 105457
    VCID: 356114CB5C8648EE69-8060
    Address 18: Aux. Heat Labels: 1K0-815-071.clb
    Part No: 1K0 815 071 T
    Component: Zuheizer 050 2504
    Revision: 00050000 Serial number: 09009839000000
    Coding: 0000011
    Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
    Part No SW: 1K0 907 530 L HW: 1K0 907 951
    Component: J533 Gateway H07 0052
    Revision: H07 01 Serial number: 261007F2001386
    Coding: EDA07F06400A028003
    Shop #: WSC 00445 210 105436
    VCID: 306F25DFA3E46DC63A-8064
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO VDD 1216
    Shop #: WSC 00000 000 00000
    Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
    Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
    Component: RNS-MID H11 5238
    Revision: AB001001 Serial number: VWZ6Z7I1376111
    Coding: 00010400040000830000
    VCID: 377D1EC3868ABAFE7B-8062
    Subsystem 1 - Part No: 1T0 919 859 B
    Component: EU West V12 8195
    Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
    Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
    Component: Tuer-SG 006 1202
    Coding: 0000693
    VCID: 387F1DFF4B94B58672-806C
    1 Fault Found:
    00109 - Left Mirror Turn Signal Lamp (L131)
    Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
    Part No: 1K2 909 144 M
    Component: EPS_ZFLS Kl.071 H08 1901
    Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
    Component: KSG PQ35 G2 020 0204
    Revision: 00020000 Serial number: 00000000000000
    Coding: 9890020851030C7F2D06840570085FC690FC00
    VCID: 0305BA1342D2265E97-8056
    Subsystem 5 - Part No: 1K0 947 291 F
    Component: Innenraumueberw.009 4809
    Coding: 00000000
    Shop #: WSC 01324
    Subsystem 6 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 7 - Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
    Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
    Coding: 0000692
    VCID: 397918FB709EAC8E8D-806C
    2 Faults Found:
    00097 - Front Passengers Central Locking (Safe) Motor (V162)
    00929 - Locking Module for Central Locking; Front Passenger Side (F221)
    008 - Implausible Signal
    Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
    Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
    Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
    Coding: 0000144
    Shop #: WSC 01324 785 1012552
    VCID: 377D1EC3468ABAFE7B-8062
    Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
    Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
    Coding: 0000144
    End-------------------------(Elapsed Time: 02:11)--------------------------
  1. RNS510 2009 to 2016 RNS510 - All ok?
    By Pulsebass in forum Passat CC
    Last Post: 03-09-2017, 01:29 PM
  2. Wanted Installer of Optical Parking System Please
    By squowse in forum In Car Entertainment
    Last Post: 07-09-2012, 11:28 AM
  3. Rear Parking Sensors with RNS510 display
    By Tups1974 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-07-2011, 10:28 PM
  4. Optical Parking System
    By reynard55 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-05-2011, 08:32 PM
  5. RNS510 Optical Parking Sensor Display
    By ThePPenguin in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-09-2009, 09:58 PM
