Thread: clutch woes
Results 1 to 10 of 17
  1. clutch woes
    Jul 2008
    Lisburn
    15 Post(s)
    Now and then Cant get gears and can creep forward at lights. 130K on the car Does the slave or master go first i checked the clutvh pedal for fluid drios dont see any? Would i?
    Knew i should have done that fluid service last year...
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  2. Re: clutch woes
    Jul 2008
    Lisburn
    15 Post(s)
    oh no proving hard to get both slave and master as they never fail....
    please tell me there is no internal mechanical failure..
    I did check the fluid level and it seems to be lower than it should, the clutch pedal seems to be dry and that is why i think slave. will have to get below her tonight ( the car) and hopefully find fluid at the slave.
    Stewart
  3. Re: clutch woes
    Mar 2009
    Montenegro
    13 Post(s)
    Maybe there is not enough oil in gearbox? Or clutch is worn?
    Sent from my LG-D802 using Tapatalk
    Audi A6 Sedan C6 2.0 TDIe 2011 Condor Grey metallic
  4. Re: clutch woes
    Jul 2008
    Lisburn
    15 Post(s)
    Happy to dissmiss both.... fingets crossed. Both these would be gradual it worked last night when i checked it, this morning nought and peddal feels touch light.
  5. Re: clutch woes
    Jul 2013
    76 Post(s)
    Check the brake fluid level to see if the level has dropped below the clutch hose.
    If if so then you either have a leak or the Slave cylinder may be leaking.
    If if you can't see a leak then check the tell tell hole in the bell housing for a wet mark.
    Dan
    2009/2010 2.0 TDIe SE
  6. Re: clutch woes
    Aug 2013
    Carlisle Cumbria
    9 Post(s)
    Slaves do fail. But my symptoms were; slight judder on first use from cold; and then just a bit of slip under large applications of torque in higher gears. So not the same as you describe. It was leaking onto the clutch plate but your possible leak may be going somewhere else. Good luck.
  7. Re: clutch woes
    Jul 2008
    Lisburn
    15 Post(s)
    Cheers just about to go lie below her in the drive way its wet windy and abrisk 5° fluid level was ok but i thought lower than what should be with new pads less than a year ago.
  8. Re: clutch woes
    Dec 2007
    8 Post(s)
    The slipping may indicate need to replace clutch,what ever the problem is should be evident when dismantled.
  9. Re: clutch woes
    Jul 2008
    Lisburn
    15 Post(s)
    After 2 hours success i could touch the slave..... bloody thing is working again also... no sign or smell of brake fluid. I am swaying to master now hmmmm
  10. Re: clutch woes
    Jul 2008
    Lisburn
    15 Post(s)
    quick update, i got elsawin fired up, to remove the slave requires part of the exhaust to come off and the gear linkage, aint going to do that in the drive just to see...
    But i did get it bleed, from above, didn't see any air or dirt come out bu the change feels slicker. drove it to work this morning about an hours drive approx 16 miles!! rush hour traffic. drove it like it was made of glass and i am sure my heart skipped a beat each time i used my left foot.
    It made it with no sign of anything untoward - if it aint broke i cant fix it....
    .... I have a rope in the boot just in case LOL
    i cant seem to find how to swap the master out in elsawin?!?!? wanted to see what hidden gems are in that job...
    i will keep the post updated,
    Stewart
  1. Fun clutch woes
    By j033y in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-01-2013, 06:11 PM
  2. Question Clutch cable woes
    By SammoVWT in forum Golf MK3 - 1993 - 1999
    Last Post: 30-03-2011, 11:04 AM
  3. Clutch woes.
    By swampy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-08-2010, 01:48 AM
  4. CCM woes
    By SKINNYSEAND in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-01-2010, 11:28 PM
  5. Gearbox/Clutch Woes
    By Racehunter in forum Beetle 2000-
    Last Post: 02-07-2009, 09:59 AM
