Re: New car snags –
08-11-2017,05:27 PM
A detailer will remove swirls maring In perfections etc but won’t remove slight dents or miss Align panels etc
befor you get your car detailed all work above should be done as if you have it coated then the Audi dealer does work or remove dents or imperfections then your have to have that panel redone at the detainers at extra cost
if they can remove inperfections when they machine polish your be ok
but would very strongly advise to get the work your not happy with done befor having it detailed
once it’s been gtechniq coated invest in some good gear wash pads wheel brushes and a good drying towel grit guards etc
regardless of being coated you can still swirl mark a car easy
a real must though if you have hard water invest in a di water softener as water marks are a coating killer
if you want any advice on cleaning equipment and discount coats just pm me
and same goes for anyone else on this forum
M
SQ7 MY17 Sepange Blue,Driving Dynamic Sports Pack,Tech Pack,Tour Pack,Park Pack,Amb Light,Pan Roof,22" V Spoke Wheels,Red Brake Cal,All Wheel Steer,Matrix Lights,Black Valcona Sports seat plus,Driver/Pass Mem,Heat/Sound Ins Glass,Heat screen,Black Upper Trim/Lower beaufort Black,Flat Sports Steer Wheel,Elec Aju Steering ,Elec Folding Mirrors Mem Heated Dim,Soft Door Close,Add Key,Load Fix,Bose Sound,Blinds,Audi Ring,Smoked Rear Lights
