Thread: Hi all another newbie needing help
Results 1 to 1 of 1
  1. Hi all another newbie needing help
    Oct 2017
    Oxfordshire
    Evening all, I’m Jamie and in need of your help!
    My son has a mk4 golf 1.4 16v 2003 model, as most of you know the gearboxes are rubbish and I had to replace it. I got a box from a 1.6 mk4 as I believe they are the same from what I’ve read online, same code on both boxes, anyway fitted the new gearbox and all was good until it started eating N/S driveshafts, he is now on his 4th driveshaft 😡 any ideas what could be wrong? All mounts are good and it’s not lowered. Also i have noticed the n/s wheel is flush with the arch if you use a level and the o/s is around 15mm inside the arch, am I using the wrong driveshaft??
    Thanks for any help.
  1. Question Newbie needing help
    By slimgsi in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 05-08-2015, 08:50 PM
  2. hi, newbie needing help...
    By gizmothedog in forum Golf MK4 - 1999 - 2004
    Last Post: 14-04-2012, 08:54 PM
  3. newbie here needing help....
    By cooper86 in forum A8 - S8 - V8
    Last Post: 01-12-2011, 10:28 AM
  4. Another newbie needing help : )
    By chr_ajr in forum New Member Introductions
    Last Post: 10-11-2008, 03:16 PM
  5. Newbie needing help
    By huzi7 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-08-2007, 12:09 PM
