Thread: Smoke whilst accelerating... ?
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. Smoke whilst accelerating... ?
    Apr 2017
    Leeds, UK
    I've got a 2002 B6 Avant, 1.9TDI 130BHP with 230,000 on the clock. It runs beautifully and I love it, but I've noticed sometimes when I accelerate through 2nd and 3rd it shoves out a fair bit of smoke for a few seconds. Weirdly, I've only ever noticed the smoke at night in the headlamps of following cars, so I don't actually know what colour it is. That's not to say it doesn't happen in the day but I can't see it.
    Is this just standard diesel behaviour or should I be concerned?
    Cheers!
  2. Re: Smoke whilst accelerating... ?
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Without seeing the smoke it would be foolhardy to make a statement of fact, but I would expect a 130 with those miles to puff a little on hard throttle, would not bother me unless it became noticeably worse or heavier.
  3. Re: Smoke whilst accelerating... ?
    Apr 2017
    Leeds, UK
    Thanks fourringsrus. The more I've kept an eye on it recently and also watched other cars of a similar age and engine (other A4s, A6s, Octavias etc of that age) the more I think it probably is just age related, so your comment is quite reassuring! Anything in particular I should be doing to keep the engine in good nick other than using decent fuel and regular servicing?
  4. Re: Smoke whilst accelerating... ?
    Oct 2009
    10 Post(s)
    Yes, regular servicing using the best materials you can afford.
    As I said before, I wouldnt make a statement of fact without seeing the smoke, but it is common for a diesel to smoke on hard revs, even when new.
    So decent air filter, decent or best recommended fuel filter for best performance, just think a poor or clogged/dirty air filter is suffocating the engines ability to breathe clean air,we dont like that so why would your engine,fuel filter poor will restrict fuel.
    Your engine needs both to be clear to get the correct measure of both in order to perform well.
    A restricted air intake will basically give more fuel, thus over fuelling and firing black smoke out the back under heavy load.
    Im sure you know most of this stuff anyway but my main point would to use the very best engine oil and filter possible and as regular as possible.
    The 130 TDI is almost bombproof and good oil/filter will maintain a healthy blood line to the unit.
    Good luck bud
    Stuart
  5. Re: Smoke whilst accelerating... ?
    Apr 2017
    Leeds, UK
    Really appreciate you taking the time to go over all that, cheers mate!
  6. Re: Smoke whilst accelerating... ?
    Nov 2017
    Scotland
    25 Post(s)
    is the EGR still hooked up ?? as under hard acceleration egr refeeds exaust into intake-thus puff of smoke if so I would pull the vac pipe off at the intake and block it with a 6mil bolt so No EGR-just fresh air into engine- because only vac pipe blocked the ECU is fooled into thinking it is still working-So no mil light on dash !! I have a3 pd 130 240,000 did have same prob untill a pal told me this we trick, worked a treat !!
  7. Re: Smoke whilst accelerating... ?
    May 2012
    Everywhere
    308 Post(s)
    As above EGR disable , inaccurate of ecu being fooled as egr isn't being monitored by ecu on earlier models as a 2002 won't prevoke an eml .
    2003 made cars will .
    2 Stroke helps too + other benefits .
  8. Re: Smoke whilst accelerating... ?
    Nov 2017
    Scotland
    25 Post(s)
    thanks for the info re egr on early modles-I didnt kno, never mind 2stroke-I have been using veg oil (sunflower oil for yrs now,neet in sumer and a we mix wi the pump stuff wen it gets realy cold- yes first two tanks I had filter too change, as it cleans the tank and hole fuel system, but after that no probs-and the last 100,000miles has been veg oil only -its a PD130 in an A3 8L 230,000miles on the clock !!
  9. Re: Smoke whilst accelerating... ?
    Nov 2017
    Scotland
    25 Post(s)
    yeh that should have read 240,000miles on it
  10. Re: Smoke whilst accelerating... ?
    Nov 2015
    West Yorkshire
    Quote Originally Posted by Gazwould View Post
    Whats this about 2 stroke?
  1. Please Help Back end twitching whilst accelerating and cornering at higher speeds
    By james.keiller91 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-06-2016, 12:03 PM
  2. Jerking whilst accelerating
    By jonyrainsforth in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-07-2015, 04:32 PM
  3. Engine smoke - whilst AC on (ECON off)
    By tobetrue123 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-01-2011, 12:08 AM
  4. Replies: 5
    Last Post: 02-11-2009, 10:44 PM
  5. Squeek whilst accelerating
    By paul3smith in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-01-2008, 11:40 PM
