Thread: Smoke whilst accelerating... ?
Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
  1. Re: Smoke whilst accelerating... ?
    #21
    Nov 2017
    Scotland
    25 Post(s)
    Quote Originally Posted by Gazwould View Post
    I'm not either , it just feels like I've entered a rabbit hole and the whole dpf debacle is for nothing because they should just of used cleaner burning sunflower oil as fuel...
    Hahaha, yeh but then the big oil comps wouldn't be making s----oads of coin !!
  2. Re: Smoke whilst accelerating... ?
    #22
    May 2012
    Everywhere
    308 Post(s)
    So as a minium how much do I need to have an effect ?
  3. Re: Smoke whilst accelerating... ?
    #23
    Nov 2017
    Scotland
    25 Post(s)
    So as a minimum how much do I need to have an effect ?
    To be honest I couldn't tell you--as I run 100% as a rule, though just this last week temp has been cold(up here above Inverness) so I put 15bucks of the pump stuff in-my tank is only 55'ish I think, but Tesco are selling 5ltrs for 5bucks (any Chinese-indian supermarket will be cheaper as they use a lot off it-sadly I don't have any near me-I'm 60miles round trip just to get to Inverness), I would throw one of them in see what you think then increase by another one or three-- keep in mind that even tho engine cranking two or three'ish times b4 starting up-aint doing any harm-IE-its getting oil circulated b4 it fires up,but if you only putting 5ltrs in starting wise, you will not see any difference at all-it will start just the same-its only in the coldest of weather that ya can have start probs as I have had because I run 100%==sunflower oil thiner-but if you mixing with the pump stuff=rape seed-veg blended-I'v even had mine running on extra virgin oil (no joke !) it smelt lovely===never had Any pump-injector or in tank lift pump prob !!!!
    But if you gonna start using a lot of it in your tank -"be prepared to change fuel filter after first couple tanks-as it drags all the crap from fuel tank walls and lines through to the filter"==but you only have it to do once-because it is them all cleaned !!!
  1. Please Help Back end twitching whilst accelerating and cornering at higher speeds
    By james.keiller91 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-06-2016, 12:03 PM
  2. Jerking whilst accelerating
    By jonyrainsforth in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-07-2015, 04:32 PM
  3. Engine smoke - whilst AC on (ECON off)
    By tobetrue123 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-01-2011, 12:08 AM
  4. Replies: 5
    Last Post: 02-11-2009, 10:44 PM
  5. Squeek whilst accelerating
    By paul3smith in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-01-2008, 11:40 PM
