Thread: Newbie with a question
  1. Newbie with a question
    Nov 2017
    Newmilns
    Hi all Looking for some help on my Audi A3 2009 1.6 tdi- I had no issue with blower before and after collision with a badger , however since coming out from bodyshop after repairs to front passenger fog light etc- the blower is not working. The garage had issues with engine immobiliser and Audi told them to disconnect battery and charge up since ECU may not be reading the keys correctly- anyway this appeared to fix the start issues - I have checked the Blower fuse and wiring around the battery and cannot see anything wrong. I read that there is a pressure sensor which could be the cause - is this located at front of car - could garage have failed to reconnect something when doing repair/respray ? I am sure the fan is OK and failure to work is a function of the garage repair.
  2. Re: Newbie with a question
    Oct 2017
    hi, try to check the fuses and if you can do a scan for fault codes, maybe appoint you in the right direction
  3. Re: Newbie with a question
    Nov 2017
    Newmilns
    Hi Thanks for the reply - the fuse for the fan is OK- I will connect scanner and see if any fault codes reported .
  4. Re: Newbie with a question
    I'd get it straight back to the garage, & if done under insurance let them know too.
  1. Newbie, with a question as always!.
    By whittle in forum New Member Introductions
    Last Post: 10-12-2011, 08:25 PM
  2. Please Help Newbie with a question?
    By WhiteGolfTdi in forum Golf MK3 - 1993 - 1999
    Last Post: 03-09-2009, 01:04 AM
  3. A4 Newbie With Question
    By a4avant4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-10-2008, 10:48 AM
  4. Newbie with question
    By scoobasteve in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-09-2008, 03:19 PM
  5. newbie with a question
    By bezzerA4 in forum Chat - Anything with wheels
    Last Post: 15-06-2008, 08:50 PM
