Thread: Loosing coolant
Results 11 to 20 of 24
  1. Re: Loosing coolant
    Feb 2016
    manchester,uk
    14 Post(s)
    Quote Originally Posted by stephenwhite990 View Post
    Only other symptom apart from loosing coolant is that it is very frothy in the header tank like washing up bubbles , I am going to try and get the head pressure tested when I finally get it off should I get it skimmed as well????
    yes head needs to be skimmed also new head bolts are required,timing belt,water pump if not changed recently. if your car has done high mileage while the head is off renew the valve seals as well.also oil and oil filter will need to changed.
  2. Re: Loosing coolant
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    Do I just get the same head gasket as the one that comes off as I believe there are three different markers on the gasket ?
  3. Re: Loosing coolant
    Dec 2014
    Bedford
    42 Post(s)
    DEFINITELY . Its all too do with piston projection. Ie how much the piston protrudes the cylinder. If yours has one hole get a one hole . One hole is the slimmest . Two hole is thicker and 3 hole is the thickest. If you get head skimmed ask the engineer for advice on gasket. I would only skim the head if it has warped.
  4. Re: Loosing coolant
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    I have started to strip it down today , cant get the bloody engine mount out no matter how high or low i lift the engine . But my main concern at the moment is - I noticed the glow plug connector rail looked a bit cracked and when I tried to pull it off the glow plugs it has snapped on all the plugs and is cracked along its length , but the wiring from it just disappears into the harness , is this easy to swap out and where is the connector to the harness ????
  5. Re: Loosing coolant
    Feb 2016
    manchester,uk
    14 Post(s)
    Changing the harness is not easy,first of all you need to chase up where the harness leads to,very rare there is a connector.
  6. Re: Loosing coolant
    Jul 2007
    glasgow
    35 Post(s)
    take the head to a machine workshop and get them to replace valve stem guides, rubber seals etc
    they are usually quite cheap for what they do
  7. Re: Loosing coolant
    #17
    Feb 2016
    manchester,uk
    14 Post(s)
    remember to renew the head bolts.
  8. Re: Loosing coolant
    #18
    Dec 2014
    Bedford
    42 Post(s)
    Remember to blow out the head bolt holes in the block. Otherwise cracking the block on refit is possible.
  9. Re: Loosing coolant
    #19
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    Head is off now , just got to remove the injectors ready for skimming and time to go shopping for gaskets , bolts , timing belt etc
  10. Re: Loosing coolant
    #20
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    Finished rebuilding it today , it starts and runs and is fine on tickover , but when reved there is a screeching / wining noise and i cant for the live of me work out if something is catching but i dont think so as it doesnt do it at tickover or if its something like no oil getting to the turbo (turbo is only 12 months old and was fine before ) . Any ideas before I sell it as spares or repairs or break it ?????????
  1. Loosing Coolant 1.8T
    By shavermcspud in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-05-2011, 10:21 PM
  2. Loosing Coolant
    By karachi_kops in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-11-2009, 07:49 PM
  3. A6 Loosing Coolant
    By Lynlea in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-10-2009, 11:25 AM
  4. V5 loosing coolant
    By Caj in forum Golf MK4 - 1999 - 2004
    Last Post: 21-09-2009, 10:56 AM
  5. Please Help Loosing coolant help!!
    By dylanlaw1979 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-03-2009, 11:35 AM
