Thread: Tube diameter for replacement audi 80 cabriolet (1996) windscreen washers
  1. Tube diameter for replacement audi 80 cabriolet (1996) windscreen washers
    Hi - as per the title, does anyone know what the correct diameter tube is that I need to purchase?
    Many thanks, Loz
  2. Re: Tube diameter for replacement audi 80 cabriolet (1996) windscreen washers
    1837 Post(s)
    Just get some washertube rom TPS, the genuine stuff is resistant to kinking.
  3. Re: Tube diameter for replacement audi 80 cabriolet (1996) windscreen washers
    Thanks. Do you have their web address? And what diameter do I need? Loz
  4. Re: Tube diameter for replacement audi 80 cabriolet (1996) windscreen washers
    Quote Originally Posted by loz65 View Post
    Crasher - would you be able to advise? Thanks.
  5. Re: Tube diameter for replacement audi 80 cabriolet (1996) windscreen washers
    1837 Post(s)
    There are VAG dealers and TPS depots all over the UK, the VAG part number is N 020 150 5 and the specification is "6x1" which I PRESUME means the OD is 6-mm and the wall thickness is 1-mm so that ASSUMES a 4-mm bore. It is £10.73 a meter BUT if they do not have it in stock they MAY insist on you having the full 5-meter roll. I stock Würth 0895 84 http://media.wuerth.com/stmedia/shop....all/04663.pdf but it is transparent, not black
    1 1 0
  1. Question 5 speed automatic (01V) fluid change interval and filler tube diameter??
    By FrenchAudi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-06-2017, 02:42 PM
  2. Question A4 Cabriolet Windscreen Trim Replacement
    By Invictagunner in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 23-08-2011, 09:59 AM
  3. Wind screen washers on Audi Cabriolet (based on 80)
    By Sokratees9 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 01-03-2010, 01:48 PM
  4. Replies: 1
    Last Post: 13-02-2010, 10:18 PM
  5. Audi Cabriolet 1996 2.0E for sale
    By John Griffiths in forum Chat - Anything with wheels
    Last Post: 25-08-2007, 09:02 AM
