Thread: MK 5 Golf 1.4 BUD Engine
  1. MK 5 Golf 1.4 BUD Engine
    Oct 2017
    Fleet
    Hi anyone have torque setting for camshaft pulley bolts and do i need new bolts ?
  2. Re: MK 5 Golf 1.4 BUD Engine
    1840 Post(s)
    Yes the bolts are one time only, get bolts and I will look up the torques.
  3. Re: MK 5 Golf 1.4 BUD Engine
    Oct 2017
    Fleet
    Thanks crasher i was thinking there about 60nm +90
  4. Re: MK 5 Golf 1.4 BUD Engine
    1840 Post(s)
    NO, way too much.... the spec is "20 Nm + 1/4 turn (90°) further, renew, use camshaft lock -T10016- to loosen and tighten"
  5. Re: MK 5 Golf 1.4 BUD Engine
    Oct 2017
    Fleet
    Thanks crasher yes all back together now and running just one query bolt supplied had 24 mm head part no N90256202 not same as original that was 16 mm head do you know if they modified it ?
  1. golf mk4 petrol engine to diesel engine conversion help
    By robokid13 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-10-2014, 07:47 AM
  2. Question Golf tdi ALH engine... Engine knocking noise. Help wanted
    By Onionss74 in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2014, 08:29 PM
  3. Question Replace injector loom in 2002 Golf TDi -ATD Engine Code - PD Engine ?
    By Negger in forum Golf MK4 - 1999 - 2004
    Last Post: 03-06-2011, 11:26 AM
  4. Replies: 1
    Last Post: 07-07-2009, 10:48 AM
  5. Changing worn transporter TDI engine to Golf engine?
    By flyin-turd in forum The Commercial Range
    Last Post: 18-01-2008, 12:28 AM
