Thread: 2010, A3, 1.2TFSI near side doors problem
  1. 2010, A3, 1.2TFSI near side doors problem
    Oct 2017
    Hi, I have a 2010 A3 and it has a problem with N/S doors: the doors doesn't lock/unlock, no red bottom lights, windows doesn't open/close (not even from driver commands), no lights on the windows button switches, the N/S mirror has no power: no indicator light, mirror adjustment doesn't work, also folding as well.
    plugged the code reader, got the fault codes :
    01332 - ECU Passenger Door - J387 No Signal/No Communication
    01333 - ECU Left Rear Door - J388 No Signal/No Communication
    Please, if someone can help to appoint me in the right direction to solve this issue would be great, thanks in advance.
  2. Re: 2010, A3, 1.2TFSI near side doors problem
    Oct 2017
    I think the door circuit is not responsive anymore. Most probably something wrong with the wire. That is why no kind of signal can reach out to it.
  3. Re: 2010, A3, 1.2TFSI near side doors problem
    Oct 2017
    Thanks for your attention.
    Well, I did checked already the wiring harness/connectors from the door pillar to the door driver side and passenger side and all seems to be ok, no broken wire, corrosion or bad connection found.
    Because I have same defect on both N/S doors, I'm thinking maybe the trouble could be somewhere upstream, on the convenience/comfort module.
    Do you know the comfort module location on 2010 A3 model?
  1. Question Help needed! Passenger side doors won't unlock.
    By Lianneed in forum Chat - Anything with wheels
    Last Post: 05-08-2017, 11:39 AM
  2. Passenger side doors wont lock
    By go-for-it1 in forum Golf MK5 - 2004 - 2009
    Last Post: 14-04-2014, 08:46 PM
  3. Please Help Stiff Front Doors - 2010 R Line
    By pappasmurf in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-02-2014, 09:59 AM
  4. Cannot shut both passenger side doors!
    By WillPassat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-01-2010, 07:54 PM
  5. Question How do I change the off-side doors window seals?
    By P Chang in forum Golf MK3 - 1993 - 1999
    Last Post: 06-03-2009, 10:26 PM
