Thread: A5 Rotor Alloy Possible Buckle Bend
  1. A5 Rotor Alloy Possible Buckle Bend
    Oct 2012
    Wakefield
    Hi i am new to the A5 forum so hi I am Luke 👋
    I recently bought an A5 sport back, its a 63 plate, it has 44,000 miles, and I love the car!
    However, I am getting an on / off vibration at high speed, all 4 tyres are like new (which makes me think the last owner was trying to get rid of this...?)
    I have had all the wheels re balanced and the garage think I have a buckled alloy
    They are the 19 rotor alloys
    I just wanted to know if they are prone to bending or buckling and if anyone has any personal experience?
    Many thanks
    Luke
  2. Re: A5 Rotor Alloy Possible Buckle Bend
    Cupar
    Possibly caused by going over a pothole? Could also be tyre out of round for same reason. Hitting speed bumps hard can cause this too. Would have thought a balancing macbine would be able to identjfy. Most likely a front so could try rotating your wheels to see if it makes any difference
  3. Re: A5 Rotor Alloy Possible Buckle Bend
    Cupar
    Did you sort? If not have you checked if you have rear wheel spacers? If you do take them out and see what happens
  4. Re: A5 Rotor Alloy Possible Buckle Bend
    Apr 2016
    Bathgate
    Got all 4 of my 19" rotors booked into a place to get the buckle sorted out. All 4 came up with an excessive inner distortion on a road force balance machine, it varied between 1.3 and 2.0mm. The 2.0 deviation was reported as the wheel needing to be replaced. At 750 a pot I’ll try to fix the wheel first. But I’ve heard that anything larger than 17” wheels tend to be at the mercy of pot holes.
  5. Re: A5 Rotor Alloy Possible Buckle Bend
    Maidstone
    Yup! I had a severly buckled front N/S alloy giving the same symptoms you describe at motorway speeds only. Had it moved to the rear for now and vibration gone, for now at least...
    Audi A5 3.0TDI 245 Black Edition S-Line Quattro Sportback 7sp Tiptronic
  1. Aftermarket Vs Genuine 19" Rotor Alloy Wheels
    By IGL2014 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-11-2014, 08:01 PM
  2. Replacement 18" Rotor Alloy Wheel
    By Tackled in forum North West England
    Last Post: 04-05-2014, 10:38 PM
  3. bend door
    By ytiablr in forum Jetta MK3 - 2005 - 2013
    Last Post: 06-07-2010, 10:06 PM
  4. Will this bend something it shouldn't?
    By RNTSI in forum Golf MK6 - 2009-2013
    Last Post: 04-06-2010, 05:16 PM
  5. steering me around the bend
    By stevesellars in forum Golf MK3 - 1993 - 1999
    Last Post: 12-10-2009, 03:58 PM
