Thread: A6 C6 4F - Are these pre-loomed to be upgraded with an auto-dimming rear view mirror?
  1. A6 C6 4F - Are these pre-loomed to be upgraded with an auto-dimming rear view mirror?
    May 2017
    Canterbury, Kent
    57 Post(s)
    I've just acquired a gen Audi auto-dimming rear view mirror (.
    I've read the "botched" retrofit upgrade at the A6 retrofit blog (which strikes me as a real bodge!) - does anyone know if there is a power plug sitting up in the headlining somewhere, behind the headlining light cluster maybe, ready to power a mirror upgrade?
    I suspect I'll need add a 5A fuse in the requisite fuse slot, but I'm trying to work out in advance, hopefully, whether this is a straight forward upgrade, or whether I'll need to create a new feed for it from somewhere in the light cluster?
    Many thanks for any advice/suggestions...
    (Don't suppose there's a howto out there somewhere that anyone knows about is there?)
  2. Re: A6 C6 4F - Are these pre-loomed to be upgraded with an auto-dimming rear view mirror?
    Feb 2009
    Ireland
    This needs a new loom installed. Power, ground, interior light feed, reverse signal from memory
  3. Re: A6 C6 4F - Are these pre-loomed to be upgraded with an auto-dimming rear view mirror?
    May 2017
    Canterbury, Kent
    57 Post(s)
    Bugger!
  4. Re: A6 C6 4F - Are these pre-loomed to be upgraded with an auto-dimming rear view mirror?
    Jul 2013
    76 Post(s)
    Use the feed from the interior light switch and don't worry about the reverse light option.
    Dan
    2009/2010 2.0 TDIe SE
  5. Re: A6 C6 4F - Are these pre-loomed to be upgraded with an auto-dimming rear view mirror?
    May 2017
    Canterbury, Kent
    57 Post(s)
    Quote Originally Posted by dan2485 View Post
    Hi Dan
    Ok, the mirror is in, and I've rigged up a feed to supply it, but can't work out which of the various plug cables I need to feed! Do you know which colour cables from the mirror cables are the + and - feeds? (I agree - I'm not worried at all about the reverse light option - all I wanted it for is looking better than the standard RVM, and for auto-dipping when idiots cruise up behind with hi or mis-aligned beams).
    Many thanks
    Richard
  6. Re: A6 C6 4F - Are these pre-loomed to be upgraded with an auto-dimming rear view mirror?
    Jul 2013
    76 Post(s)
    Dan
  7. Re: A6 C6 4F - Are these pre-loomed to be upgraded with an auto-dimming rear view mirror?
    May 2017
    Canterbury, Kent
    57 Post(s)
    Thank you for the links Dan.
    Stupidly, I've removed the six wires from the mirror plug. I can work that Black/White are 1 and 2 in the plug, but can't work out where the other three go in the plug? I know I don't need it to complete the exercise, but if/when I remove the mirror if/when I sell the car, it would be pretty handy!
  1. Auto dimming rear view mirror wiring
    By crazy4alfa in forum Retrofits
    Last Post: 25-10-2013, 10:37 PM
  2. Auto Dimming Rear View Mirror
    By skibuddy in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 05-11-2012, 06:53 PM
  3. I've got myself an auto dimming rear view mirror. Help.
    By Ben in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-06-2011, 06:56 PM
  4. Wiring - Auto dimming rear view mirror
    By CDEmerton in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-02-2010, 06:45 PM
  5. Auto dimming rear view mirror
    By smarts in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-11-2007, 02:58 PM
