I'm going to attempt to replace a door lock actuator at the weekend, is there a fuse I can pull to disable the airbag in the door while I'm doing it? I'd rather avoid disconnecting the battery if I can, it's a pain reprogramming the stereo.I have VCDS so can reset error codes if I need to.Thanks!
