Thread: Increasingly heavy steering on my Golf VI estate
Results 1 to 10 of 11
  1. Increasingly heavy steering on my Golf VI estate
    Aug 2015
    Copenhagen
    Have a Golf VI estate. I was't sure whether this of the mk V forum was the best place, given what's beneath the skin, but anyway:
    the steering on our Golf (nov 2010) feels (is) increasingly heavy. It's not entirely without PAS but it's going the wrong way
    Tyre pressure's are fine, so no issue there.
    No warning lights have appeared and the car was recently at service so (I guess) not warnings 'pinged' on VAGCOM
    I have a nasty feeling that this is gonna involve a horribly expensive steering rack fix, but is there anything else it could be that i could be looking into? I currently live in Denmark, where labour rates are around 2-3 times in the UK, so if it's gonna be a crippling expensive bill we'll probably consider p/ex'ing the car for a VII or something similar
    Any advice would be greatly appreciated
  2. Re: Increasingly heavy steering on my Golf VI estate
    Dec 2014
    Bedford
    31 Post(s)
    Quote Originally Posted by tillster View Post
    You can swap the rack in like less than 2 hour's. But there a real pain to setup after and I reccomend going to a main dealer or a Vw specialist. Cost will be massive new. Dont think in the UK at a Vw dealer you would get much change out of 1500/ 2000 .
  3. Re: Increasingly heavy steering on my Golf VI estate
    glasgow
    26 Post(s)
    have you checked the power steering oil reservoir ?
    could be low on oil or needs changed
  4. Re: Increasingly heavy steering on my Golf VI estate
    Dec 2014
    Bedford
    31 Post(s)
    Quote Originally Posted by niall campbell View Post
    It's electric power steering.
  5. Re: Increasingly heavy steering on my Golf VI estate
    Aug 2015
    Copenhagen
    Thanks Flapperjack. Bugger bugger bugger
    Does anyone know : are there any other known issues / quick fixes that could negate the issue a wee while?
    Mrs Tillster uses the car for her commute - I don't really fancy her dealing with the surprise of the PAS going when she's out in the car.
  6. Re: Increasingly heavy steering on my Golf VI estate
    Aug 2015
    Copenhagen
    Hi Niall. As flapperjack said, it's an electrical motor on the V/VI
    From what I've read, a steering motor failure often requires replacing the entire steering rack.
  7. Re: Increasingly heavy steering on my Golf VI estate
    Sep 2009
    Stoke on Trent, England
    Quote Originally Posted by FLAPPERJACK76 View Post
    Its electric but it but it still has a reservoir on the right under the bonnet.
    You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  8. Re: Increasingly heavy steering on my Golf VI estate
    Dec 2014
    Bedford
    31 Post(s)
    There's no resevoir. It's all electric.
  9. Re: Increasingly heavy steering on my Golf VI estate
    Oct 2012
    Leeds
    I have similar Issue on my 2010 passat estate. Every now and then I feel the steering becomes hard as if there is no power steering for 2 to 3 Seconds and the power steering becomes active. It does happen sometimes, not sure you are having the same Issue.
    I am very worried now because of the cost if the Power steering fails. Strangely there isn't any fault code or lights when the Issue Happens. Can you please confirm if the Issue you are experiencing is as same as mine? Does any one else experiencing similar Problems?
  10. Re: Increasingly heavy steering on my Golf VI estate
    Aug 2015
    Copenhagen
    The 'low-powered' PAS on my golf sounds different to yours, insofar as my issue is constant, not intermittent, and doesn't - yet- involve he complete loss of PAS
    Good luck with yours !
  1. heavy duty spring help 1.9 tdi 03 estate
    By s4s in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-05-2014, 02:20 PM
  2. heavy steering
    By mister chief in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-05-2014, 07:49 AM
  3. steering very heavy
    By ten in forum Golf MK5 - 2004 - 2009
    Last Post: 21-08-2009, 11:06 PM
  4. Please Help A3 Heavy steering
    By stuarts911 in forum Audi A3 - Archive Topics
    Last Post: 21-03-2009, 11:12 PM
  5. VW Golf MK4 GT TDi Heavy Steering Problems
    By Time Dependant in forum Golf MK4 - 1999 - 2004
    Last Post: 11-09-2008, 05:45 PM
