Thread: Need advice
  1. Need advice
    May 2010
    york
    I have recently had to remove the oil filter housing / oil cooler unit on my Daughters 2010 Golf tdi 140. It was refitted using a new gasket & stretch bolts tightened to 15 NM, then 1/4 turn. after refilling the cooling system and purging air out I have run the car for approx. 100 miles, temp. is normal and heater ok. However coolant level has fallen and low level warning has come on. There are no signs of water leaking externally and no signs of water in the oil and oil level still normal. Can anyone advise me as to what is going on. Could there still be air in the cooling system?. Any advice would be welcome as I don't want to damage the engine.. Regards, Edward..
  2. Re: Need advice
    Apr 2017
    wirral
    hi is this the first time since doing filter housing ,i did a lot of coolant jobs including oil filter cooler and housing removal,long story,anyway coolant level took a long time to find its own level ,dropped a few times but eventually found its level and has stayed there since ,i was topping up about a litre each time ,is that the amount on yours or is it a lot more
  3. Re: Need advice
    Feb 2004
    Yorkshire
    34 Post(s)
    It may help if you post I the correct section related to the vehicles, this is just for site issues..
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Member of the Institute Of Advanced Motorists
    Member of Skoda Owners Club GB
    Automotive Parts Specialist - VAG Group Automotive Parts Specialist
  1. Please Help Looking for a A4 Cab- advice
    By lewie226 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-03-2011, 12:29 AM
  2. Please Help Some advice regarding A4/A6
    By MegaSparks in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-06-2009, 06:57 PM
  3. How To Advice with TDC
    By a.sib in forum Polo - Derby - Lupo - Fox
    Last Post: 13-03-2009, 10:22 AM
  4. Looking to buy an A3 - advice please!
    By royster-doyster in forum Audi A3 - Archive Topics
    Last Post: 03-01-2008, 10:47 PM
  5. A4 1.8T advice
    By robby71 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-12-2007, 11:40 PM
