Thread: Secondhand Purchase - Vagcom reading
  1. Secondhand Purchase - Vagcom reading
    Mar 2010
    Galway, Ireland
    My son bought a '13 B8.5 facelift model with some superficial frontal damage. Now repaired, and a new bulb put in the left hand Bi-xenon, there doesn't seem to be any power getting to the bulb.
    I ran the vagcom on the car and thought I'd post it here to see if anyone can pick up on what the problem might be... along with some of the other faults
    Thanks in advance!
    Mileage: 194440km-120819miles
    05-Acc/Start Auth. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: Sporadic communication error 1000
    2E-Media Player 3 -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CGLC) Labels:. 03L-906-018-CGL.clb
    Part No SW: 03L 906018 JGHW: 03L 906 018 JL
    Component: R4 2,0LEDCH25 2839
    Revision:45H25---
    Coding: 0A194012242401080000
    Shop #: WSC 06208000 00000
    ASAM Dataset:EV_ECM20TDI01103L906018JG 003005
    ROD:EV_ECM20TDI01103L906018JG.rod
    VCID:78F49F5DC3014286B2-802C
    7 Faults Found:
    4698 - Function Restriction due to Faults in Other Modules
    U1113 00[032] - -
    Intermittent- Not Confirmed - Tested Since Memory Clear
    FreezeFrame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 194235 km
    Date: 2017.10.19
    Time: 22:04:20
    Engine speed: 831.50 /min
    Normed load value: 25.1 %
    Vehicle speed: 0 km/h
    Coolant temperature: 63 °C
    Intake air temperature: 16 °C
    Ambient air pressure: 980 mbar
    Voltage terminal 30: 14.520 V
    Unlearning counter according OBD: 38
    Cruise Control System (CCS):switch position-Bit 0: 10000001
    Cruise Control System (CCS): status-Bit 0: 00101000
    Cruise control switch-off: irreversible-Bit 0: 11111111
    Cruise control switch-off: reversible-Bit 0: 11111111
    Cruise Control System: specified speed: 0.00 km/h
    Engine control module reset status-Bit 0: 00000000
    Engine control module reset status-Bit 8: 00000000
    Cruise control switch-off: irreversible w. brake intervention-Bit 0:00000000
    4699 - Function Restriction due to Faults in Other Modules
    U1113 00[032] - -
    FreezeFrame:
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 194235 km
    Date: 2017.10.19
    Time: 22:04:20
    Cruise Control System (CCS): switch position-Bit 0: 10000001
    Cruise Control System (CCS): status-Bit 0:00101000
    Cruise control switch-off: irreversible w. brake intervention-Bit 0: 00000000
    5211 - Fuel Rail/System Pressure
    P0087 00[096] - Too Low
    FreezeFrame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 193462 km
    Date: 2017.10.10
    Time: 08:31:52
    Engine speed: 1815.50 /min
    Normed load value: 65.9 %
    Vehicle speed: 48 km/h
    Coolant temperature: 65 °C
    Intake air temperature: 23 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 13.420 V
    Unlearning counter according OBD: 17
    Fuel temperature: 15.2 °C
    Mean injection quantity: 32.25 mg/stroke
    Rail pressure regulation: status-Bit 0: 00000101
    Fuel high pressure: actual value: 97500 hPa
    High fuel pressure: specified value: 1.0809e+006 hPa
    Pressure control valve adaptation factor: 1.1160
    Fuel level: 27.00 l
    5212 - Fuel Rail/System Pressure
    5215 - Fuel Rail/System Pressure
    FreezeFrame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 193462 km
    Date: 2017.10.10
    Time: 08:31:52
    Engine speed: 1787.50 /min
    Normed load value: 95.7 %
    Voltage terminal 30: 13.440 V
    Mean injection quantity: 47.70 mg/stroke
    Rail pressure regulation: status-Bit 0:00000101
    High fuel pressure: specified value: 1.0725e+006 hPa
    Fuel level: 27.00 l
    5231 - Fuel Rail/System Pressure
    FreezeFrame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 193462 km
    Date: 2017.10.10
    Time: 08:31:53
    Engine speed: 1595.50 /min
    Normed load value: 0.8 %
    Vehicle speed: 46 km/h
    Unlearning counter according OBD: 16
    Mean injection quantity: 0.13 mg/stroke
    Rail pressure regulation: status-Bit 0: 00000100
    Fuel high pressure: actual value: 82900 hPa
    High fuel pressure: specified value: 410600 hPa
    Fuel level: 27.00 l
    5582 - Oil Pressure Switch for reduced Oil Pressure
    P164D 00[032] - Malfunction
    FreezeFrame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 193596 km
    Date: 2017.10.11
    Time: 23:43:28
    Engine speed: 829.00 /min
    Normed load value: 19.2 %
    Coolant temperature: 104 °C
    Intake air temperature: 63 °C
    Ambient air pressure: 1010 mbar
    Voltage terminal 30: 13.080 V
    Unlearning counter according OBD: 23
    Fuel consumption: 0.56 l/h
    Engine oil temperature: 103.2 °C
    Oil warning threshold: 45.176 mm
    Status of oil pressure switches-Bit 0: 00000000
    Oil fill level: 72.376 mm
    Outside air temperature: 26.5 °C
    Fuel temperature: 43.3 °C
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
    Part No SW: 8K0 907379 CGHW: 8K0 907 379 CG
    Component: ESP8frontH09 0100
    Revision:--------Serial number: --------------
    Coding: 161544
    Shop #: WSC 06325000 00000
    VCID:0004F7BD93D10A468A-8054
    2 Faults Found:
    00473 - Control Module for Elect. Park/Hand Brake (J540)
    013 -Check DTC Memory - Intermittent
    FreezeFrame:
    Fault Status: 00101101
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 222
    Mileage: 193596 km
    Time Indication: 0
    Date: 2017.10.11
    Time: 22:35:19
    FreezeFrame:
    Hex Value: 0x0000
    Hex Value: 0x4026
    Hex Value: 0x1215
    Hex Value: 0x09B6
    Hex Value: 0x0000
    00285 - ABS Wheel Speed Sensor; Front Right (G45)
    003 -Mechanical Failure - Intermittent - MIL ON
    FreezeFrame:
    Fault Status: 10100011
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 221
    Mileage: 194235 km
    Time Indication: 0
    Date: 2017.10.19
    Time: 22:04:20
    FreezeFrame:
    Hex Value: 0x0000
    Hex Value: 0x40A6
    Hex Value: 0x123C
    Hex Value: 0xA8B5
    Hex Value: 0x0000
    Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
    Part No SW: 8K0 907064 GEHW: 8K0 907 064 FE
    Component: BCM22.0H12 0633
    Revision:00002001
    Coding:03B14000000000000000
    VCID:79F29A59F00B5B8ECD-802C
    Subsystem 1 - PartNo SW: 8K0 959 754 HHW: 8K0 959 754 H
    Component:FBSAUDIB8 IDGH71 0083
    Serial number:0813000051351012
    Subsystem 2 - PartNo SW: 8K0 905 852 EHW: 8K0 905 852 E
    Component: J764 ELVMLBH40 0046
    Serial number:2313000055904011
    1 Fault Found:
    00166 - Access/Start Authorization Switch (E415)
    004 - NoSignal/Communication - Intermittent
    FreezeFrame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 224
    Mileage: 194442 km
    Time Indication: 0
    Date: 2017.10.20
    Time: 19:53:59
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8K2 820043 AHHW: 8K2 820 043 AH
    Component: KLIMA 3ZONEN H04 0122
    Revision: D0000000Serial number: 01130420130320
    Coding: 342402E000
    VCID:6FE6A401BE4F053E63-803A
    No fault code found.
    Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
    Part No SW: 8K0 907063 DGHW: 8K0 907 063 DG
    Component: BCM11.0H16 0103
    Revision:07016001Serial number: 00000594347501
    Coding:260000108034AFC00081400000001D0D001D0308270 90201000008000400020100000024000000
    VCID:77F69C61C61F4DFEBB-8022
    Subsystem 1 - PartNo SW: 8K2 955 119 AHW: 8T2 955119Labels: 1KX-955-119.CLB
    Component: WWS120413H06 0080
    Serial number:SWF13040120064
    Coding: 00FD11
    Subsystem 2 - PartNo SW: 8U0 955 559 BHW: 8U0 955 559BLabels: 8U0-955-559.CLB
    Component:G397_RLFSH06 0002
    Serial number:21200912
    Coding: 02005D
    Subsystem 3 - PartNo SW: 8K0 941 531 ASHW: 8K0 941 531AS
    Component: E1 -LDSH03 0031
    Serial number:00000000000604131309
    Subsystem 4 - PartNo SW: 4H0 907 658HW: 4H0 907 658
    Component:AQ_Hum_SensorH03 0003
    Serial number:C50840A6000000000001
    4 Faults Found:
    02988 - Left-Hand/Right-Hand Traffic Switchover Active
    000 --
    FreezeFrame:
    Fault Status: 01100000
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 25
    Mileage: 187511 km
    Time Indication: 0
    Date: 2017.04.24
    Time: 14:30:34
    01316 - ABS Control Module
    FreezeFrame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 221
    Mileage: 194235 km
    Time Indication: 0
    Date: 2017.10.19
    Time: 22:04:25
    01800 - Light Switch (E1)
    FreezeFrame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 224
    Mileage: 194442 km
    Time Indication: 0
    Date: 2017.10.20
    Time: 19:53:42
    00978 - Lamp for Low Beam; Left (M29)
    012 -Electrical Fault in Circuit
    FreezeFrame:
    Fault Status: 01101100
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 119
    Mileage: 191833 km
    Time Indication: 0
    Date: 2017.08.12
    Time: 21:44:54
    Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
    Part No SW: 8K0 959655 NHW: 8K0 959 655 N
    Component:AirbagVW-AU10 H45 0610
    Serial number:003KFD99K86H
    Coding:30534435363030303030554A3052384B3053
    Shop #: WSC 61974001 1048576
    ASAM Dataset: EV_AirbaECUVWAUDI010003010
    ROD:EV_AirbaECUVWAUDI010_003_AU48.rod
    VCID:48942F9DF361F20602-801C
    Crash sensor forside airbag: driver side:
    Serial number:6334MSME7A44004FH
    Crash sensor forside airbag: front passenger side:
    Serial number:6344MSME7A756D36V
    Crash sensor forside airbag: rear: driver side:
    Serial number:6352QSME403235587
    Crash sensor forside airbag: rear: passenger side:
    Serial number:6362QSME1934175EM
    Crash sensor forfront airbag: driver side:
    Serial number:63732SME7D2F175EK
    Crash sensor forfront airbag: front passenger side:
    Serial number:63832SME1A301D7C4
    Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
    Part No SW: 8R0 953568 QHW: 8R0 953 568 Q
    Component:Lenks.ModulH02 0171
    Revision:00000000Serial number: 20130415000429
    Coding: 000016
    VCID: 4FA604811E0F253E43-801A
    Component: E221 -MFLH03 0004
    1 Fault Found:
    FreezeFrame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 221
    Mileage: 194235 km
    Time Indication: 0
    Date: 2017.10.19
    Time: 22:04:20
    Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
    Part No SW: 8K0 920982 EHW: 8K0 920 982 E
    Component:KOMBIINSTR.H35 0556
    Revision:00400000Serial number: UVR56294E
    Coding:3384080002012600010000
    VCID:36685165819574F660-8062
    Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
    Part No SW: 8R0 907468 LHW: 8R0 907 468 A
    Component: GW-BEM5CANH11 0056
    Revision:1V080027Serial number: 2741V1340282A5
    Coding: 80CF07FF00
    VCID:48942F9DFB61F20602-801C
    Subsystem 1 - PartNo SW: 8T0 915 181HW: 8T0 915 181
    Component:J367-BDMHellaH03 8041
    Serial number:5045750303
    Subsystem 2 - PartNo SW: 8K0 959 663 BHW: 8K0 959 663 B
    Component:J532_DCDCStabH05 0006
    Serial number:13101003335011200410
    1 Fault Found:
    01317 - Control Module in Instrument Cluster (J285)
    FreezeFrame:
    FaultPriority: 2
    Fault Frequency: 1
    Reset counter: 224
    Mileage: 194442 km
    Time Indication: 0
    Date: 2017.10.20
    Time: 19:54:53
    Freeze Frame:
    Bin. Bits:10000
    Voltage: 12.30 V
    Count: 7
    Bin. Bits:10000
    Time: 3.50 s
    Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
    Part No SW: 8T0 035785 AHW: 8T0 035 785
    Component: SGext.Player H08 0290
    Revision:00000000
    Coding: 020202
    VCID:39725A59B08B9B8E8D-806C
    1 Fault Found:
    01330 - Central Control Module for Central Convenience(J393)
    FreezeFrame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 224
    Time Indication: 0
    Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
    Part No SW: 8T0 959793 QHW: 8T0 959 793 F
    Component: TSGFAH09 0305
    Coding:011002204001410001
    VCID: 57B6FCE126DF6DFE9B-8002
    Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
    Part No SW: 8K0 909144 FHW: 8K0 909 144 B
    Component:RCEPSH37 0507
    Revision:00001000Serial number: 0010385677
    Coding:100000000001
    Shop #: WSC 06324000 00000
    ASAM Dataset:EV_RCEPSAU48X 008014
    ROD:EV_RCEPSAU48X_008.rod
    VCID:346C6B6D9FE966E65E-8060
    1 Fault Found:
    3164944 - Function Restriction due to Faults in OtherModules
    U1113 00[008] - -
    Intermittent- Confirmed - Tested Since Memory Clear
    FreezeFrame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 221
    Mileage: 194235 km
    Date: 2017.10.19
    Time: 22:04:21
    valid
    Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
    Revision:00002001Serial number:0305237123
    Coding:011B062200B900408020013680000000
    Subsystem 1 - PartNo: 8K0 951 177
    ComponentWA-SensorH02 0040
    Subsystem 2 - PartNo: 1K0 951 605 C
    Component: LINBACKUP HOH05 1501
    Address 47: Sound System (J525) Labels:. 8T0-035-223-BOC.clb
    Part No SW: 8T1 035223HW: 8T1 035 223
    Component: DSPPremH05 0040
    Revision:00005001Serial number: 94803013176501
    Coding: 0203010302
    VCID:6CDCB30D8F59FE2646-8038
    Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
    Part No SW: 8T0 959792 QHW: 8T0 959 792 H
    Component: TSGBFH08 0305
    VCID:56A8F1E521D554F680-8002
    2 Faults Found:
    00110 - Right Mirror Turn Signal Lamp (L132)
    012 -Electrical Fault in Circuit - Intermittent
    FreezeFrame:
    Fault Status: 00101100
    Fault Priority: 3
    Fault Frequency: 254
    Reset counter: 219
    Mileage: 187511 km
    Time Indication: 0
    Date: 2017.04.24
    Time: 14:31:02
    02111 - Motor for Window Regulator
    005 - Noor Incorrect Basic Setting / Adaptation - Intermittent
    FreezeFrame:
    Fault Status: 00100101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 193556 km
    Time Indication: 0
    Date: 2017.10.11
    Time: 09:27:11
    Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
    Part No SW: 8K0 907801 LHW: 8K0 907 801 J
    Component:EPB-4H01 0003
    Revision:--------Serial number: 00000001290713
    ASAM Dataset:EV_ParkiBrake 001027
    ROD:EV_ParkiBrake_VW51.rod
    VCID:38745F5D8381828672-806C
    2 Faults Found:
    131584 - Switch for Electric Parking Brake
    C100C 07[008] - Mechanical Failure
    FreezeFrame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 207
    Mileage: 193596 km
    Date: 2017.10.11
    Time: 22:35:00
    Voltage terminal 30: 14.8 V
    Internal Fault ID: 11
    Network management state: normal
    Function light in parking brake button: OFF
    Red operating lamp: On
    Red warning lamp: OFF
    Green operating lamp: OFF
    Yellow warning lamp: OFF
    Terminal 15 status: On
    RWU: not active
    DSD: not active
    HTR: not active
    ECD: not active
    ACC requested apply: not active
    Auto Adjust: not active
    General Inspection Function: not active
    Internal Parking Brake state: static
    Statusof parking brake button: Open
    Status ParkingBrake left: Set
    Status ParkingBrake right: Set
    459776 - Function Restriction due to Faults in Other Modules
    U1113 00[008] - -
    FreezeFrame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 221
    Mileage: 194235 km
    Date: 2017.10.19
    Time: 22:04:21
    Voltage terminal 30: 14.7 V
    Internal Fault ID: 140
    Function light in parking brake button: On
    RWU: not active
    DSD: not active
    HTR: not active
    ECD: not active
    Status of parking brake button: Not operated
    Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
    Part No SW: 8R2 035186 PHW: 8R2 035 186 P
    Component: Concert3DABH06 0470
    Revision:00000002Serial number: AUZ5Z6M1883019
    Coding:0403008201018D00035B071800
    VCID:438E38B1C247D15ED7-8016
    Subsystem 1 - PartNo SW: 8T0 919 603 GHW: 8T0 919 603 G
    Componentisplay
    Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
    Part No SW: 8T0 959795 QHW: 8T0 959 795 H
    Component: TSGHLH07 0305
    Coding:010002204001210001
    VCID:59B2FAD950CB7B8EAD-800C
    Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
    Component: TSGHRH07 0305
    Revision: --------Serial number: --------------
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8T0 862335 FHW: 8T0 862 335 E
    Component: FSE_256xBTH45 0660
    Revision:00000000Serial number: 00000005640040
    Coding: 0010320
    VCID:3D7A4E4964A3A7AEA1-8068
    '09 A4 SE 143hp Multitronic - Quartz Grey
  2. Re: Secondhand Purchase - Vagcom reading
    Mar 2017
    First thing to do is clear all codes and see what ones (if any) return.
  3. Re: Secondhand Purchase - Vagcom reading
    Mar 2010
    Galway, Ireland
    Hi Mario, yes, I have tried that and al errors return. Found some info on another forum through a google search that says it could be a number of different issues that can raise this ' 459776 - Function Restriction due to Faults in Other Modules' but, TBH, I'm at a loss where to start?
  1. ESP Light Vagcom reading needed
    By zed2k in forum VCDS - Help Requests
    Last Post: 08-09-2009, 08:20 PM
  2. vagcom 805.1 partial reading only?
    By a4_jim in forum VCDS - General Questions
    Last Post: 06-12-2008, 04:27 PM
  3. MAF reading with vagcom
    By bakili in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-11-2008, 11:37 PM
  4. Reading Air/Fuel ratio with vagcom. HOW?
    Last Post: 17-07-2008, 08:36 AM
  5. VAGCOM - When buying a secondhand passat?
    By piers in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-07-2007, 09:20 PM
