Hi, I just scanned my car and there was 2 faults on Address 17 and Address 19. I deleted all faults, and scanned car again. After this step Address 17 fault was there again. Does anyone can decode fault? Please find my log below.
Thank you in advance!
Cheers!
Thursday,19,October,2017,19:26:11:04550
VCDS Version: 15.7.0.2
Data version: 20150820
Ross-Tech: Home
VIN: TMBAB6NEXE0212529 License Plate:
Mileage: 47028km-29221mi Repair Order:
Chassis Type: NE (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 20 42 44 52 55 5F
VIN: TMBAB6NEXE0212529 Mileage: 47028km-29221miles
01-Engine -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CJZA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 H HW: 04E 907 309 A
Component: 1.2l R4 TSI X09 6392
Revision: WAX09---
Coding: 01190032232401080000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM12TFS01104E906016H 001007
ROD: EV_ECM12TFS01104E906016H.rod
VCID: 2744EB370FEDEDBA7EEA651-8072
No fault code found.
Readiness: 0010 0000
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 609140000006CB
Coding: 1A076A911421296E007C060241CC245856289400608224F000 230030C002
Shop #: WSC 73430 031 00063
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_SK37.rod
VCID: 4B8C7787B3C5E9DABA92E91-801E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5E0 907 044 E HW: 5E0 907 044 E
Component: Climatronic H02 0805
Revision: 00001K06
Coding: 01010004000100011005004000100800
ASAM Dataset: EV_ACClimaBHBVW37X 003017
ROD: EV_ACClimaBHBVW37X_SK37.rod
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011409001403
Coding: 0C000B42424722FB47E0400000080708000000000000000000 0000000000
Shop #: WSC 73430 790 00205
ASAM Dataset: EV_BCMCONTI 012001
ROD: EV_BCMBOSCH_AU37.rod
VCID: 7BECE747A3E5995A4AB2991-802E
Slave 1:
Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 140402 041 0570
Serial number: 140407014137
Coding: 0E4DFD
Slave 2:
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y14M04D13H02M06S08S9
Coding: 02805D
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-283.clb
Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
Component: PARKHILFE 4K H09 0033
Revision: -------- Serial number: 60831410100238
Coding: 0001050001
ASAM Dataset: EV_EPHVA14AU3700000 002018
ROD: EV_EPHVA14AU3700000_SK37.rod
VCID: 3866384BD2537242E750BE5-806C
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 3Q0 959 655 AD HW: 3Q0 959 655 AD
Component: Airbag VW20 012 0189
Revision: -------- Serial number: 003P5P688497
Coding: 88CCC00000000000400000CC000800000065
ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
ROD: EV_AirbaVW20TS6VW48X_SK37.rod
VCID: 001690ABCA03FA821F60D65-8054
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: ----------- HW: 454 000 304 14
Component: SideSensor_Df 008 0887
Serial number: 3576U0000006B8102F08
Coding: 2D2D2D
Crash sensor for side airbag; front passenger side:
Subsystem 2 - Part No SW: ----------- HW: 454 000 604 14
Component: SideSensor_Pf 008 0887
Serial number: 3586U000000F2A94AF0V
Coding: 2D2D2D
Crash sensor for side airbag; rear; driver side:
Subsystem 3 - Part No SW: ----------- HW: 454 800 504 14
Component: SideSensor_Dr 111 0148
Serial number: 3516R5CCC5A03000000F
Coding: 2D2D2D
Crash sensor for side airbag; rear; passenger side:
Subsystem 4 - Part No SW: ----------- HW: 454 802 803 14
Component: SideSensor_Pr 111 0148
Serial number: 3526R192E4D030000003
Coding: 2D2D2D
Crash sensor for front airbag; driver side:
Subsystem 5 - Part No SW: ----------- HW: 454 800 703 14
Component: FrontSensor_D 114 0149
Serial number: 3556V22971E030000002
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 Q HW: 5Q0 953 549
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 08041404221383
Coding: 1000
ASAM Dataset: EV_SMLSKLOMQB 009001
ROD: EV_SMLSKLOMQB_SK37.rod
VCID: 449E5CBB9E9B26A27BC83A5-8010
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 5E0 920 871 B HW: 5E0 920 871 B
Component: KOMBI 333 2210
Coding: 07AC02002980000801087A00040000
Shop #: WSC 73430 031 00205
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_AU37.rod
2 Faults Found:
16777020 - Function Restricted due to Interrupted Communications
U1110 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 182
Mileage: 47028 km
Date: 2017.10.19
Time: 19:20:08
16777022 - Function Restricted due to Interrupted Communications
U1110 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 182
Mileage: 47028 km
Date: 2017.10.19
Time: 19:20:08
Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001788225
Coding: 030100042F085700EF00024A080F0001000105000000000000 0000000000
ASAM Dataset: EV_GatewLear 010015
ROD: EV_GatewLear.rod
VCID: 3F945357F77D457A261A6D1-806A
Alternator:
Multifunction unit control module:
Subsystem 2 - Part No SW: 5E0 919 719 HW: 5E0 919 719
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000C1238110114
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 4408213103
Address 20: High Beam Assist. (J844) Labels: 8X0-857-511.clb
Part No SW: 5G0 857 511 D HW: 5G0 857 511
Component: FLA H04 0002
Revision: AA001001
Coding: 02018F6B76765D525220343E01
ASAM Dataset: EV_HighBeamAssisAU37X 001009
ROD: EV_HighBeamAssisAU37X.rod
VCID: 2B4C17071305C9DA9AD2091-807E
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 B HW: 5Q4 959 593 B
Component: TSG FS 009 0014
Serial number: 0000098928372
Coding: 00150120D000040000001100
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Component: FOND_FHSG_DRV 005 0005
Serial number: 00000000000002352383
Coding: 010200
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 0102
ASAM Dataset: EV_SteerAssisMQB 010031
ROD: EV_SteerAssisMQB.rod
VCID: 419055AF8189338A50EE1B9-8014
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B
Component: TSG BFS 009 0014
Serial number: 0000099026616
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
VCID: 439C5FA79B95219A42C2311-8016
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Component: FOND_FHSG_PSG 005 0005
Serial number: 00000000000002347286
Coding: 190200
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Revision: -------- Serial number: --------------
Coding: 03CA02003F000000
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
ROD: EV_HeadlRegulVWAFS_SE26.rod
VCID: 409650AB8A833A825FE0165-8014
Subsystem 1 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0009
Coding: 3E0000
Subsystem 2 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0009
Coding: 3E0000
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 5E0 035 812 A HW: 5E0 035 812 A
Component: MU-S--ER 040 0421
Serial number: S0C00104143407
Coding: 03730100FF0000005011000100000000000000840100010000
ASAM Dataset: EV_MUStd4CPASE 002039
ROD: EV_MUStd4CPASE_SK37.rod
VCID: 1E2ACED350B72C720D4C98D-804A
Media Player Position 1:
Subsystem 1 - Part No SW: 5E0 919 605 A HW: 5E0 919 605 A
Component: ABT_Std_nPhon H50 0022
Serial number: SKZ8Z9PK500ASA
End-------------------------(Elapsed Time: 03:14)--------------------------
