Thread: HELP HELP steering pump part number
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
  1. Re: HELP HELP steering pump part number
    #21
    Oct 2017
    Birmingham
    Okay will do tomorrow,
    I owe you lots of beer after this is fixed your the only person helping me out. 😉
  2. Re: HELP HELP steering pump part number
    #22
    Dec 2014
    Bedford
    42 Post(s)
    Help you as much as i can , im a bit rusty with vcds though. I used to use it years ago. Im currently using ... cant remember what its called but its blooming brilliant. Spent 23 years on vws audis skodas and Seats. Last 2 years i have been working as an mot tester and work on everything now. Pm me your reg im sure theres another fuse to check . F7 maybe . Not the metal strip fuse but a normal type fuse.
  3. Re: HELP HELP steering pump part number
    #23
    Dec 2014
    Bedford
    42 Post(s)
    Check fuse F7 5 amp in fascia fuse panel. When you open drivers door its on the right of the dashboard.
  4. Re: HELP HELP steering pump part number
    #24
    Dec 2014
    Bedford
    42 Post(s)
    Also check your earth points see photo attached.
  5. Re: HELP HELP steering pump part number
    #25
    Dec 2014
    Bedford
    42 Post(s)
    Wiring diagram.
  6. Re: HELP HELP steering pump part number
    #26
    Oct 2017
    Birmingham
  7. Re: HELP HELP steering pump part number
    #27
    Oct 2017
    Birmingham
  8. Re: HELP HELP steering pump part number
    #28
    Oct 2017
    Birmingham
    Did what you said, also checked all the fuses in that bord there all fine. I'm going to call VW tomorrow to see if I can get the original pump number.
  9. Re: HELP HELP steering pump part number
    #29
    Dec 2014
    Bedford
    42 Post(s)
    Its your pump . You can clearly see its running at 7.5 volts. Which is approximately half alternator voltage. So one of the two electrical bridges has failed inside the pump. There is no current displayed because the steering motor won't run on 7.5 volts.
  10. Re: HELP HELP steering pump part number
    #30
    Oct 2017
    Birmingham
    Quote Originally Posted by FLAPPERJACK76 View Post
    So what pump am I ordering? We know this was changed and didn't work and the number wasn't checked before ordering.
  1. Modified steering hose part number for steering judder ?
    By Tara in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 11-11-2015, 08:57 PM
  2. Power Steering Pump part Number Anyone?
    By Brycie in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-07-2014, 06:38 PM
  3. Please Help ABS Pump part number and price
    By bwfcspider in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-08-2010, 09:19 PM
  4. fuel pump part number ?
    By bez101 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-09-2009, 02:46 PM
  5. part number on air con pump
    By coupe2 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-05-2009, 06:40 PM
