Thread: HELP HELP steering pump part number
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 42
  1. Re: HELP HELP steering pump part number
    Oct 2017
    Birmingham
    Okay have now downloaded VCDS and have someone codes.
    00920 something to do with heated mirrors
    01598 drive battery voltage. Signal too low
    00906 horn
    00975 heated rear window
    01044 control module incorrectly coded
    I think this is the radio code.
    01309 power steering control module (j500) no communication _intermittent
    00778 steering angle sensor (g85) no communication
    00566 steering assistance operation
    Implausible signal _intermittent
    00816 power steering sensor (g250)
    Open or short to plus _intermittent
    00779 outside air temperature sensor
    00588 airbag igniter drives side
    01321 control module for airbag
    Alot I know only really interested with the steering problem for now.
    I has a quick Google around the steering sensor and it mentions about the wheel being straight and both front wheels pointed forward, my steering wheel has to be at 9 o'clock for the front wheels to be pointing forward.
    Any help would be much appreciated i have no idea what to do first.
  2. Re: HELP HELP steering pump part number
    Dec 2014
    Bedford
    42 Post(s)
    First thing I would do is disconnect battery wheels in the straight ahead position. Remove airbag remove steering wheel. Put steering wheel back on in the straight ahead position and fit airbag. Connect the battery. Erase all the faults . Turn steering full left and hold then full right and hold then drive it forwards upto 30 mph. Re check faults come post whats there. If steering is still heavy remove nsf bumper grille or fog lamp whatever is fitted and check the power supply at the pump and make sure you have a good earth. Middle plug with large wires.
  3. Re: HELP HELP steering pump part number
    Oct 2017
    Birmingham
    Okay so I've done what you advised wheels straight disconnected the battery steering wheel off, back on the the correct position reconnected the battery and cleared the codes, all the way to the left and hold then the right hand side and drove it.
    Still have the same codes as before for the power steering a few have gone like the airbag and mirrors.
    Still the steering isn't working correctly, I noticed after the test drive the was oil leaking from the front bumper so removed the wheel arch liner and the fog light to have a look.
    There's oil leaking from the pump somewhere I can't tell where as it's covered in oil, firstly I have the part number from the pump and it's 6Q0423156AB I know it was changed by the previous owner and didn't fix the problem so he abandoned it but as said before he just simply got a pump never checked any numbers. Looking at what you said before about my number should be it doesn't match.
    On the vcds the pump vag number is the same 6Q0423156AB so I take it its taking to it some how, or could this be the correct pump?
    I then looked at the angle sensor as I thought it was new it isn't in fact the plug at the rack end is broken it can just simply be pulled off.
    Now onto the power feed I didn't check there was power to the pump I'll do that tomorrow, but I was really struggling to get an earth tred on a few places can't seem to find a reading, I'll check that again was it was raining and I didn't want to be outside too long 😂.
    I'm pretty sure I'm going to replace the pump first but don't want to order anything until I get advice from you.
    Jordan
  4. Re: HELP HELP steering pump part number
    Oct 2017
    Birmingham
    Also if it means anything under the current pump part number on vcds soft coding 00110 would this be my original code or this pumps code?
  5. Re: HELP HELP steering pump part number
    Dec 2014
    Bedford
    42 Post(s)
    This pumps code 00110 is i think the heaviest setting . Can you post measured values in steering. ? Its probably the best way for me to spot an anomoly.
  6. Re: HELP HELP steering pump part number
    Dec 2014
    Bedford
    42 Post(s)
    Quote Originally Posted by FLAPPERJACK76 View Post
    You could change it to 00150 which should be the maximum lightest. From memory they leave the factory on 00140.
  7. Re: HELP HELP steering pump part number
    #17
    Oct 2017
    Birmingham
    How would I go about getting measured values? I'm new to this software. Also can I just click on that code and change it?
    I've completely removed the pump now as I was certain it was wrong.
    Would it be possible to just ring vw and ask them what the original part number is? I can simply just buy the correct pump then.
  8. Re: HELP HELP steering pump part number
    #18
    Dec 2014
    Bedford
    42 Post(s)
    Quote Originally Posted by Slevan7 View Post
    You could but they dont like giving out part numbers. Worth a try. You could just plug the pump back in . Go to steering. Click measured values and photo the values on your phone and to post them here.
  9. Re: HELP HELP steering pump part number
    #19
    Oct 2017
    Birmingham
    Okay ☹️ I'll have to get some new fluid then tomorrow.
    What if I just got a steering rack and pump from the same vehicle would that be an easy fix? Or is it still a problem with part numbers?
  10. Re: HELP HELP steering pump part number
    #20
    Dec 2014
    Bedford
    42 Post(s)
    Okay ️ I'll have to get some new fluid then tomorrow.
    No .. dont bother with the fluid. Just plug it back in . Take the measured values and post them. Put pipes back on. Takes a few mins. Your only going to start it it will be ok.
  1. Modified steering hose part number for steering judder ?
    By Tara in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 11-11-2015, 08:57 PM
  2. Power Steering Pump part Number Anyone?
    By Brycie in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-07-2014, 06:38 PM
  3. Please Help ABS Pump part number and price
    By bwfcspider in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-08-2010, 09:19 PM
  4. fuel pump part number ?
    By bez101 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-09-2009, 02:46 PM
  5. part number on air con pump
    By coupe2 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-05-2009, 06:40 PM
