Thread: Brake pads
Results 1 to 8 of 8
  1. Brake pads
    Feb 2017
    Stockport
    6 Post(s)
    Hey guys.
    Anyone know if the “Brake Pads” yellow alert on my dash is for front or rear?
    Then that takes me on too...
    Bosch pads or Pagid?
    I will change them myself if on the front unless they are abnormally different to any other car
  2. Re: Brake pads
    Jul 2013
    Yorkshire
    18 Post(s)
    Could be either, you will tell if you look at the sensor wires on the nearsides, one will be worn through. I would guess at front.
    Pads are different for various models. look on Euro car parts web site. if you buy from them don't forget there always a discount code somewhere.
  3. Re: Brake pads
    Mar 2013
    Northwest
    7 Post(s)
    Fronts are 20 minutes a side (if that), straightforward job. Rears will need the auto hand brake servo wound back. I need to do ours and have the (Bembo) pads but trying to find a simple method of backing off the auto handbrake and then re-calibrating it with the new pads.
    Looking at OBDeleven as an option - has anyone else used this for changing the rear pads? Experiences?
    Audi A6 Allroad 245 in Dakota Grey (2013)
    Audi SQ5 (C+S) in Ultra Blue (2022)
    Yamaha DT400E in Competition Yellow (1977)
  4. Re: Brake pads
    Jul 2013
    Yorkshire
    18 Post(s)
    Quote Originally Posted by Allroad_2013 View Post
    I used VCDS, simple job providing procedure is followed. Wouldn’t try doing it without winding back this way, ilve heard stories of EPB damage.
  5. Re: Brake pads
    Mar 2014
    Edinburgh
    235 Post(s)
    Quote Originally Posted by sh4d0w View Post
    Hey guys.
    There’s quite a few variation on pads and discs for the A6. Look in your service book for the sticker that has the PR codes. It will have something like 2EA.
    This place is pretty cheap. Buy Car Parts direct online: cheap Auto Parts, Car Spares, Car Parts UK
    If you look up the part numbers on the trw or Brembo websites you can search there.
    Careful with non branded or euro branded stuff as I’ve seen some pads crumble under use and brakes aren’t a thing to mess about with on a 2 ton car. Can’t go wrong with Brembo or trw.
  6. Re: Brake pads
    Mar 2013
    Northwest
    7 Post(s)
    Quote Originally Posted by A6ian View Post
    I was looking for a cheaper alternative to getting VCDS and buying the Rosstech cable. OBDeleven can be had for Ł70 ish on eBay, whereas the Ross-tech cables are Ł200 ish.
  7. Re: Brake pads
    Jun 2016
    NSW Australia
    The obdeleven works beautifully today for me when changing my rear brake pads. Very simple and even better with the latest updates.
    Sent from my SM-G955F using Tapatalk
  8. Re: Brake pads
    Feb 2017
    Stockport
    6 Post(s)
    Thanks all. Still need to get this done
  1. Replies: 1
    Last Post: 31-12-2010, 08:47 AM
  2. 51 plate Bora - New pads, how to avoid "Check Brake Pads"?
    By unkleGsif in forum Bora - 1998 - 2005
    Last Post: 09-03-2010, 09:40 PM
