Thread: Cruise control problems when turning left
  1. Cruise control problems when turning left
    My cruise control is working perfectly in every sense of the word with just the one problem. When I press the lever to go left it turns off the cruise control and the car slows, which is rather awkward when you have passed a vehicle on the motorway and want to indicate that you are pulling back in.
    It started off occasionally, but is now 'always'. I have experimented by being extremely careful how I touch the lever, and even pressing the lever at the steering wheel end turns it all off.
    Any ideas?
  2. Re: Cruise control problems when turning left
    Dec 2017
    Roeselare
    Same here.
    I guess it is something rare.
    As my A6 is from 2004, with 370000km it most probably points to some wear out. Perhaps a cable or contact issue?
    Can anyone point to some documentation on how to open-up or access the indicator area?
  3. Re: Cruise control problems when turning left
    1837 Post(s)
    That is going to be a column switch unit fault.
  4. Re: Cruise control problems when turning left
    Dec 2017
    Roeselare
    Hi Crasher, thanks for replying.
    Are you pointing to a replacement of that unit or can it be inspected for possible error?
  1. Replies: 9
    Last Post: 17-02-2016, 06:59 PM
  2. Early A4 B5 cruise control fitting problems.
    By Mudchute in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-03-2014, 10:49 PM
  3. Problems with cruise control on EXEO when towing
    By hughestg in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 04-01-2013, 05:46 PM
  4. Question Cruise control turning off on its own
    By Jettadame in forum Jetta MK3 - 2005 - 2013
    Last Post: 06-05-2009, 10:34 PM
  5. Cruise Control Problems Golf mk4 estate
    By swheeler in forum Golf MK4 - 1999 - 2004
    Last Post: 26-02-2009, 09:13 AM
