Thread: Start-up problem, 'FUSE' warning light showing
  1. Start-up problem, 'FUSE' warning light showing
    Nov 2016
    Hey folks,
    My 03 8L won't start up, the battery isn't flat because I can unlock it remotely and switch on lights etc.
    But when I turn the key I just get a succession of clicks and then nothing.
    The 'FUSE' warning light appeared on the main console, so I checked all the fuses in the main fuse box on the drivers side and all looked fine.
    Or is there more fuses I should check? Or could it be something else? Like a faulty relay?
    Any help or suggestions would be much appreciated.
    Cheers.
  2. Re: Start-up problem, 'FUSE' warning light showing
    Southern County Softy
    Try a known good battery.
    A4 2.5 tdi QS (mapped)
  3. Re: Start-up problem, 'FUSE' warning light showing
    Nov 2017
    Scotland
    25 Post(s)
    I had same prob, turned out that battery had no amps-had 12volts, but it was caput-no amps so click click wen try to start !!
  4. Re: Start-up problem, 'FUSE' warning light showing
    Nov 2016
    Very late reply... But yes this worked. Couldn't jump from my girlfriends car, but recovery van came out and jump started it first time...
  5. Re: Start-up problem, 'FUSE' warning light showing
    Nov 2016
  1. A6 C5 Battery died and showing FUSE on trip.
    By Bahamacharger in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-11-2016, 10:32 PM
  2. Brake light warning on, but nothing showing on a scan. Any ideas?
    By Phutters in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-04-2016, 06:53 PM
  3. VW golf MK4 showing ABS light and warning sign
    By joecranejoe in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 19-08-2010, 10:21 PM
  4. Polo brake light fuse problem
    By iandy in forum Polo - Derby - Lupo - Fox
    Last Post: 09-04-2008, 02:12 PM
  5. golf mk5 want start problem with fuse board in engine
    By rudeboy in forum Golf MK5 - 2004 - 2009
    Last Post: 02-01-2008, 07:10 AM
