Thread: BXE 1.9 PD Tdi Engine Problems (2008 Golf Plus)
  1. BXE 1.9 PD Tdi Engine Problems (2008 Golf Plus)
    Oct 2017
    London
    12 Post(s)
    Does anyone have any experience with problems on this engine? Its 2008 with 147,000 miles. Sounds fine on tick over but with low revs becomes very noisy and a little smokey.
    I have VCDS and can provide any numbers on something that might give me any clues.
    The head is coming off in the next week as I believe it may be a camshaft failure but am not 100%
    Anyone with advice or experience would be much appreciated.
  2. Re: BXE 1.9 PD Tdi Engine Problems (2008 Golf Plus)
    Oct 2017
    London
    12 Post(s)
    Head is off and cam has signs of wear. Is there any chance the bottom end is damaged?
  3. Re: BXE 1.9 PD Tdi Engine Problems (2008 Golf Plus)
    May 2012
    Everywhere
    308 Post(s)
    What service schedule has it been on ?
  4. Re: BXE 1.9 PD Tdi Engine Problems (2008 Golf Plus)
    Oct 2017
    London
    12 Post(s)
    Customer has no books so can’t see any history sadly!
  5. Re: BXE 1.9 PD Tdi Engine Problems (2008 Golf Plus)
    May 2012
    Everywhere
    308 Post(s)
    Cars sold with absent service history normally have been neglected and cam wear as a result .
    BXE has it's challenges....
  6. Re: BXE 1.9 PD Tdi Engine Problems (2008 Golf Plus)
    Oct 2017
    London
    12 Post(s)
    Normally would any of those challenges be in the bottom end? Or am I likely to cure the problem replacing the cam? Thanks
  7. Re: BXE 1.9 PD Tdi Engine Problems (2008 Golf Plus)
    May 2012
    Everywhere
    308 Post(s)
    They have a tendency to ware through a upper crank big end bearing shell , spot weld and throw a leg out of bed .
    New cam and upper and lower big end shells I would .
  8. Re: BXE 1.9 PD Tdi Engine Problems (2008 Golf Plus)
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Using the wrong oil can lead to excessive cam wear.
    Skoda Octavia II SE 1.9PD TDI
  9. Re: BXE 1.9 PD Tdi Engine Problems (2008 Golf Plus)
    Oct 2017
    London
    12 Post(s)
    Turned out to be worn camshaft lobes, now replaced and running perfect.
  1. Please Help Fuses in engine compartment (2008 Golf Est TDi)
    By NZMax in forum Golf MK5 - 2004 - 2009
    Last Post: 24-08-2013, 12:41 AM
  2. HELP! Golf mk4 2.0 GTi Engine problems!!
    By Richie_Rich in forum Golf MK4 - 1999 - 2004
    Last Post: 25-06-2013, 02:31 PM
  3. Question Golf 2008 1.9TDI 42k Squeak/chirp from engine when take foot off throttle?
    By leeanderin in forum Golf MK5 - 2004 - 2009
    Last Post: 11-10-2012, 03:35 PM
  4. Golf 1.4 with engine problems
    By interceptor1983 in forum Golf MK4 - 1999 - 2004
    Last Post: 17-09-2009, 06:39 PM
  5. Question What engine oil to use in a Golf Mk5 GTI (2008) ???
    By shaft-50 in forum Golf MK5 - 2004 - 2009
    Last Post: 09-03-2009, 11:56 PM
