Thread: HELP!!!! 1.6 TDi, starts and dies out!
  1. HELP!!!! 1.6 TDi, starts and dies out!
    Sep 2017
    Tyrone
    I have developed a problem on my MK6 Golf 1.6 TDi, below lists what happened:
    On the way home from work it started to stumble coming up to a junction. It nearly completely died out when trying to pull away, I put it into neutral and revved it and the 'misfire' went away (The revs wouldn't go up freely for a few seconds when i tried to take off, as if they were blocked when the throttle was pressed)
    On the way home the glow plug light started to flash. As soon as I pulled up to my driveway to reverse in, the car dies out. Try to start it again, it runs for 10 seconds maximum but wouldn't idle correctly and pressing the throttle didn't make any difference (if anything it died out quicker)
    Now the car starts OK, but when it does idle for the 10-12 seconds it starts to run rough and dies out - It puts out white coloured smoke also
    No codes with VCDS and another an Autel diagnostic my mechanic uses. My EGR and DPF have been remapped out of the ECU, with the DPF being gutted out.
    The car is November 2009, covered around 100k miles
    Please help!!!
  2. Re: HELP!!!! 1.6 TDi, starts and dies out!
    Sep 2017
    Tyrone
    bump
  1. mk2 1.8gti starts but dies
    By robingold1 in forum 8v - Engine
    Last Post: 17-01-2011, 08:00 AM
  2. more problems starts and dies
    By minty0_10 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-01-2010, 07:09 PM
  3. help a4 estate 1.9 tdi 130 starts then dies
    By foegal-2008 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-11-2009, 10:30 AM
  4. Please Help 2.5 tdi starts, runs 1 second and dies
    By scotchydoodle in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-02-2009, 09:55 PM
  5. Please Help GTI 16v starts then immediately dies!
    By mikecarty51 in forum Golf MK3 - 1993 - 1999
    Last Post: 29-08-2008, 08:17 PM
