Thread: 2002 GT TDI: Fuel Filler Flap/Cover Won't Always Open From Handbrake Button!
  1. 2002 GT TDI: Fuel Filler Flap/Cover Won't Always Open From Handbrake Button!
    May 2017
    Canterbury, Kent
    37 Post(s)
    Hello again
    This is a slightly more irritating issue. Issue 2 out of 2!
    It simply won't open all of the time. I reckon, since I've been driving it for the last few weeks, that you need to press the button four or five times on average to actually make it open. When you press the button by the handbrake, it will mostly make an audible noise that's coming from the mechanism that releases the filler catch. However, on the occasions where you can hear a noise, but it doesn't open, it's quite quiet.
    On the occasion, after multiple presses, where it pops into life and the filler cover actually opens, there is a much louder noise coming from the mechanism that releases the cover. It's kind of if, the mechanism is sticking, and it needs four or five goes to free it up.
    Therefore, given that I can hear a feint noise most of the time when I press the button - does this suggest that the intermittent fault is more likely to lie with the release mechanism itself, than the button by the handbrake? Ifso, can this be lubed or oiled, or something else done if it's "sticking"? I can't even see how you'd access it, as it's clearly sitting behind the rear quarter-panel, and looks it's a real pain in the derriere to actually reach!
    As always - many thanks indeed for any pointers and suggestions to resolve this!
  2. Re: 2002 GT TDI: Fuel Filler Flap/Cover Won't Always Open From Handbrake Button!
    Aug 2017
    North Yorkshire
  3. Re: 2002 GT TDI: Fuel Filler Flap/Cover Won't Always Open From Handbrake Button!
    May 2017
    Canterbury, Kent
    37 Post(s)
    Thanks very much for replying DubNut - in the end I ordered a replacement button from a VW breaker and popped it in. It seemed to work much more reliably, and thus far (touch wood), I've not yet had an instance where it hasn't opened, but it's still early days!
    I remain hopeful that the new button has resolved it.
    Thanks for the link to replace the solenoid - what a total **** that the poster has removed all of the pics from his hosting site!
  1. Please Help How to manually open fuel filler flap
    By SteveySteve in forum Golf MK5 - 2004 - 2009
    Last Post: 11-03-2016, 08:37 PM
  2. Fuel filler flap
    By Lost slip in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-03-2016, 03:24 PM
  3. Can't open fuel flap with button
    By tomandjo2 in forum A2
    Last Post: 25-05-2011, 09:57 PM
  4. Fuel Filler Flap won't close
    By baulchy in forum Golf MK4 - 1999 - 2004
    Last Post: 15-09-2009, 11:45 AM
  5. fuel filler flap
    By yogise in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-08-2009, 09:31 PM
