Thread: How do you remove the ECU?
Results 1 to 10 of 10
  1. How do you remove the ECU?
    negev Guest
    Can anyone point me at a guide for removing the ECU from a B5?
    From what I've gathered so far:
    1) Turn it off with the wipers pointing up (?)
    2) Unbolt the wiper arms
    3) Remove the plastic piece of trim near the wiper arms
    4) Remove some screws
    5) Get access to the ECU box
    is that basically it or am I missing important steps?
  2. Re: How do you remove the ECU?
    negev Guest
    Oh, and disconnect the battery before unplugging the ECU obviously
  3. Re: How do you remove the ECU?
    uk
    I thought the ECU was under the carpet of the front passenger footwell or am I getting confused with another one, I had a few boxes out a year or so ago.
  4. Re: How do you remove the ECU?
    Jan 2017
    Dublin
    Ccm is under the passenger floor, Thats for the central locking and other modules as far as I am aware
    Engine Ecu is drivers side under the plastic scuttle that covers pelum chamber,Open black box there and the ecu should be there
  5. Re: How do you remove the ECU?
    May 2012
    Everywhere
    308 Post(s)
    Don't forget to renew the gasket , cheap .
  6. Re: How do you remove the ECU?
    negev Guest
    thanks!
  7. Re: How do you remove the ECU?
    uk
    Ah, I stand corrected, that explains why my central locking has a mind of its own after I found the CCM immersed in water.
  8. Re: How do you remove the ECU?
    May 2012
    Everywhere
    308 Post(s)
    Passat rule #1 , plenum drains and pollen filter housing .
  9. Re: How do you remove the ECU?
    uk
    All done now but if only I'd known, hindsight ...... Thanks anyway.
  10. Re: How do you remove the ECU?
    scotland
    39 Post(s)
    Buy a replacement wiper scuttle cover 99.9% chance it will break, it’s just under £20 from the dealer.
  1. Replies: 2
    Last Post: 31-03-2015, 09:39 PM
  2. Do I need to remove CD changer to remove the glove box? A4 Avant 2007
    By cornishpasty in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-02-2015, 10:06 PM
  3. 2.7T - What Can I Remove?
    By Henk Kommers in forum Chat - Anything with wheels
    Last Post: 13-10-2014, 04:45 PM
  4. How to remove sat nav/hi fi
    By hughjass in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-04-2013, 05:38 AM
  5. Question how to remove remove aero windscreen wiper...
    By Hotrocks888 in forum Chat - Anything with wheels
    Last Post: 22-11-2008, 04:45 PM
