Thread: VW Golf Mk 5 Radio Stuck in Safe 2 Mode
  1. Solved - VW Golf Mk 5 Radio Stuck in Safe 2 Mode
    Oct 2017
    wiltshire
    Was wondering if anyone can help me.
    I recently purchased a VW Golf Mk 5, got the radio code, but when I went to enter it, it was already in SAFE 2 mode. I've done as suggested in the manual and left the radio on with the key in the ignition for 1+ hours but the radio has not reset, I've also tried disconnecting the battery for 10 mins but this didn't work either.
    Anyone got any other suggestions before I look into purchasing a new one?
    Thanks!
  2. Re: VW Golf Mk 5 Radio Stuck in Safe 2 Mode
    May 2007
    17 Post(s)
    How long you need to leave it with the ignition on depends on how many times someone has tried to enter the wrong code.
    You shouldn't really ever need to enter the code on those radios. You only need the code when the radio is fitted to a different car because it reads the car chassis No. off the CAN BUS.
    There is a way to override safe mode using VCDS but I'm not sure if the works on the RCD300/500.
  3. Re: VW Golf Mk 5 Radio Stuck in Safe 2 Mode
    Oct 2017
    wiltshire
    Thanks for your reply!
    All fixed now, drove it for just over an hour and it reset itself.
  1. stereo stuck in safe mode - help required
    By sister in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-10-2010, 06:27 PM
  2. Please Help RCD 200 stuck in safe mode
    By chrisroffey in forum In Car Entertainment
    Last Post: 26-05-2010, 10:18 PM
  3. A6 Symphony Stuck In Safe Mode
    By toffer in forum In Car Entertainment
    Last Post: 05-04-2010, 07:55 PM
  4. delta cc soundsystem stuck in safe mode
    By wall263 in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 10-02-2010, 03:51 AM
  5. Safe Mode Radio Help
    By mcevoyj2 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-06-2007, 09:40 AM
