I was wondering if any of you out there have ever seen this or can think of some other option to try.
I have a temperature gauge that wont move off 60.
When I turn the ignition on the gauge moves as if it is then active, so I know there is power.
So the usual fix would be change the sensor, I did this twice, the last was a Febi unit.
I have rewired 2 plugs for it with no better result.
If I use a paper clip and short connection 1 and 2, then turn the ignition on, the gauge shoots right up, so I am guessing the gauge actually works.
I have used Vagcom light to read the ecu info and the dash signal info while taking it for a drive, the temperature rises to 90 and stays put so I also know its not the stat.
I have no error codes also.
I am completely stumped with this one so any light you guys could shine would be greatly appreciated!
