Thread: Urgent help please guys
  1. Urgent help please guys
    Sep 2008
    Bolton Lancs
    6 Post(s)
    Hi Guys im in the middle of doing my balance shaft on my 2.0 BMR tdi and I cannot work out which locking tool I should use the one with the silver knob I cannot get to line up and seat correctly and the one with the black knob I can get to seat but the timing marks do not line up correctly and both tools are two teeth different so which tool should I be using
  2. Re: Urgent help please guys
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    The correct one for a BMR is the T10100 which aligns the crank arrow at roughly 1pm. To ensure this is correct, with the top timing belt cover removed, you should be able to insert the 2 cam pins into the centre of the lower left oval slot (exhaust cam) and lower right oval slot (inlet cam) to fully lock the timing. The cam pins should go right in as they have to enter the 2 drilled holes in the camshaft bearing frame behind when the toothed cam sprocket 'windows' are at the top of the cams.
    PM me your email address and I can send you pictures of where they all should be as mine is a BMR also.
    Edit: Just to add - if the arrow on your locking tool is on a tooth then it can only align with an arrow pointing at a corresponding groove on the crank. Similarly if the arrow on your locking tool is pointing at a groove it can only align with an arrow pointing on the tooth of your crank. Your crank has the arrow pointing at a groove which therefore can only match the locking tool with an arrow on a tooth of the locking tool - the T10100 tool.
    Mad Mitch
  1. Helllp please!!!!urgent help please guys!!!!
    By Samuraibunni in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-03-2012, 08:52 PM
  2. Urgent help please guys
    By mdibb2009 in forum Wheels and Tyres
    Last Post: 07-09-2011, 12:16 AM
  3. Please Help passat b5 2.8 v6 urgent help needed please guys ..
    By ALP77 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-08-2010, 11:53 AM
  4. help!!!urgent!!!please!!
    By aaronsagas in forum Audi A3 - Archive Topics
    Last Post: 16-05-2008, 04:44 PM
  5. URGENT HELP .6N X reg Polo Automatic gear issue - Urgent Help please!
    By javednazeer in forum Polo - Derby - Lupo - Fox
    Last Post: 12-03-2008, 08:26 PM
