Hi , I had the emissions fix done at main dealer and afterwards suffered constant regen of dpf. I then had a few weeks later engine light show up on dash , took it back to VW dealer and they fixed faulty lambda sensor free of charge just a week ago.
Now i am having intermittent starting issues , it does it maybe once or twice a week but will take 4-5 attempts to start the engine , dying out after it catches each time , and when it does start it sounds rough for a few seconds .
Is this the cam sensor maybe or is it temp sensor , no lights are showing on the instrument panel , although a battery test showed battery needs replacement .
Im worried the car may break down and im not sure if VW dealer will honour a second fix free of charge.
greatful for any advice ..many thanks ..
