Thread: Missing Seal/cap? Help with part number
  1. Missing Seal/cap? Help with part number
    Sep 2017
    Copenhagen, Denmark
    Hey all, new to the group and I need some help. I picked up this 99 golf mk4 for a screaming deal with the knowledge that it needs some work. Luckily, I haver the time and experience to make it happen.
    But, on this item Im stuck. The car is a 1.6sr with 5speed manual trans. As you can see by the photo, there is a missing plug or seal or bung from the top side of the tranny. I obviously want to replace this asap, but Im having trouble finding th part number. Does this motor/trans combination look familiar to anyone, and if so, can you point me in the right direction to a replacement??IMG_0006.jpg
  2. Re: Missing Seal/cap? Help with part number
    1840 Post(s)
    That is the plug for the timing inspection mark on the flywheel/box for setting valve timing. It is a 27mm plug with bung, I will look up the number but it has been the same since 1974.....
  3. Re: Missing Seal/cap? Help with part number
    Dec 2014
    Bedford
    42 Post(s)
    020301129D is the green plug
    020301132 is the cover.
  1. 2002 1.9tdi AWX Coolant Flange Seal Part Number
    By AudiAvantAwx in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-09-2017, 06:35 PM
  2. Missing trim - part number / name?
    By Beardy_Bear in forum Golf Plus
    Last Post: 21-12-2015, 05:32 PM
  3. Question 1.6 FSI Injector Seal Kit Part Number
    By megzdad in forum Golf MK5 - 2004 - 2009
    Last Post: 10-09-2015, 10:33 AM
  4. Replies: 13
    Last Post: 21-02-2014, 06:04 PM
  5. Missing part - audi says part of design
    By psyho in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-07-2009, 01:50 PM
