Thread: seized wheel bearing to hub asembly
Results 1 to 8 of 8
  1. seized wheel bearing to hub asembly
    Aug 2007
    Hook Hampshire
    21 Post(s)
    I am trying to replace the front bearing on my A7 but cannot remove the hub/bearing assembly from the strut because its seized on. I have tried hammering it and twisting it. Can anyone tell me how best to do this.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  2. Re: seized wheel bearing to hub asembly
    Mar 2017
    Northampton
    Add a bit of heat? Might expand enough to free it up
  3. Re: seized wheel bearing to hub asembly
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Thanks Def33, tried a lot of heat but still it did not budge. I used a slide hammer and managed to pull the hub out and parts of the bearing. I then tried hammering from the back. Still no luck. I have now taken off the strut, which itself was a pig of a job. I will try pressing the bearing off tomorrow but will need to find a plate about 88mm in diameter for the press to push on to.
    What is annoying is that the use of aluminium parts on metal parts means that the surfaces stick together. This will be a nightmare and expensive as the vehicle gets older. i may have a few hundred pounds to spend if I have to replace the strutt.
  4. Re: seized wheel bearing to hub asembly
    1840 Post(s)
    They are terrible things to get out, a cast iron bearing in an aluminium upright exposed to salt water, now which engineer would imagine that would not be a service problem? All they had to do was slather some anti seize compound around and it would not be the hammer beating issue it turns into, we dread doing them. We have tried LOTS of heat with our proper hot spanner oxy set and multijet heating nozzle, no help, so much ally just absorbs and dissipates the heat. We haven't tried an induction heater as we can't find one big enough.... Taking the upright off is as you say a sketch because the steel top bolt seizes into the upright top location... crap build quality......
  5. Re: seized wheel bearing to hub asembly
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Nice to hear from you Crasher. Do you think a 10 ton press will work. When I spray Ferrosol between the flanges, the fluid disappears, so that must be a good sign.
  6. Re: seized wheel bearing to hub asembly
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    If and when you get the bearing out it would be worth checking the strut for cracks after all that heat hammering and pressing, just in case it has been damaged.
  7. Re: seized wheel bearing to hub asembly
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Not sure how you check for cracks other than visual. Anyone know what a new strut costs.
  8. Re: seized wheel bearing to hub asembly
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Job done eventually. That's taken me 2 days, so hardly a saving on costs. The hydraulic press was the answer. I guess a garage would take about 3 hours. What I have done though is learnt a lot about my A7 and dismantled greased all the parts which should make future replacements so much easier.
    Now I really should look at the other side
  1. 2003 S4 Avant headlight asembly - where to buy
    By Graham Townsend in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-04-2014, 07:13 AM
  2. HELP! Seized Wheel!
    By ianc1990 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 05-04-2014, 05:54 AM
  3. Attention Alloy wheel seized to hub!
    By legendamongus in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 29-11-2010, 01:10 AM
  4. How To Change wheel bearing rear wheel
    By thecableguy12 in forum Golf MK3 - 1993 - 1999
    Last Post: 20-11-2009, 01:56 PM
  5. Question Wheel bearing noise not a Wheel bearing
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-10-2009, 10:31 PM
