Thread: Do you need to drain the gearbox oil to remove the ECU?
  1. Do you need to drain the gearbox oil to remove the TCU?
    Dec 2016
    Glasgow
    I need to remove the gearbox ECU on my A4 B6 Cabriolet 1.8T as I have flashing PRNDS lights etc, however I am getting mixed advise on whether the TCU can be removed with or without draining the gearbox of oil first? Does anyone know for certain?
    I have attached a photo of the ECU type I wish to remove that sits on the bacl of my CVT gearbox .
  2. Re: Do you need to drain the gearbox oil to remove the ECU?
    Sep 2017
    Latvia
    You have to drain oil if you want to remove ECU. That requires special tool. Also, for gearbox backfilling you need another special tool, and it probably won't be possible to buy it.
  3. Re: Do you need to drain the gearbox oil to remove the TCU?
    Feb 2011
    Sutton Coldfield England
    These people are a bit far from your location but Milta Technology (Bristol Gearbox Center) are the absolute experts at the kind of job you need
    removed repaired and refitted my Multitronic ECU for £300 whilst I waited and watched. I was very impressed
    To answer your question Yes fluid has to be drained and then pumped back in in an Exact quantity at the right temperature
    Bobh
  4. Re: Do you need to drain the gearbox oil to remove the TCU?
    Aberdeen
    63 Post(s)
    Try M ac kie Transmission in Glasgow. They can read the gearbox ECU for faults I think. Also servicing etc.
  5. Re: Do you need to drain the gearbox oil to remove the TCU?
    Dec 2016
    Glasgow
    Many thanks, I've been told about the temperature too.
  1. Do I need to remove CD changer to remove the glove box? A4 Avant 2007
    By cornishpasty in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-02-2015, 10:06 PM
  2. How To Remove battery without removing windscreen cowling & drain plenum, inc TDi
    By cazyp in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-11-2014, 03:03 PM
  3. do you have to drain engine oil to remove crankcase emission system?
    By sonic in forum Polo - Derby - Lupo - Fox
    Last Post: 13-12-2010, 07:43 PM
  4. Battery drain traced to auto gearbox fuse - now what?
    By mjcon in forum Polo - Derby - Lupo - Fox
    Last Post: 22-09-2010, 02:16 PM
  5. Oil level and drain plugs T4 gearbox
    By hallii in forum The Commercial Range
    Last Post: 14-04-2009, 11:22 AM
