Thread: 1999 Golf GTI T, unusual noise from front offside wheel and sporadic starting issue.
  1. 1999 Golf GTI T, unusual noise from front offside wheel and sporadic starting issue.
    Sep 2017
    sanremo italy
    Hi All, so I have at last become the owner of a GTI. The Car was purchased in UK last week and then driven back to Italy where I work at the moment.
    For 48 hrs in Uk the car drove faultlessly with no problems. Time to board the ferry and although the engine turned over just fine it just would not fire. Panicked a bit, could see nothing disconnected or loose then hey presto 20 mins later it started without a problem, unfortunately since getting the car home it has done this a few more times, is this an electrical or immobiliser issue??.
    So driving down thru france and probably been going for about 4 hours when I notice what can only be described as a rubbing noise from front offside wheel, quite a high pitched noise but upon inspection everything seemed okay, throughout the journey this then also developed a clicking noise too, so we have the whiney rubbing noise and clicking noise all from same place. The only thing I can think is poss cv joint/driveshaft issue?? I am pretty sure it is not brakes etc but some advice on these 2 issues would be greatly appreciated. Many thanks in advance.jp
  2. Re: 1999 Golf GTI T, unusual noise from front offside wheel and sporadic starting issue.
    Dec 2007
    8 Post(s)
    The noise may possibly have been a road chipping caught in brake assy.
    An immo. issue normally allows start up but shut down in seconds.A key symbol would also show in dash.
    A vcds scan would be helpful.
  3. Re: 1999 Golf GTI T, unusual noise from front offside wheel and sporadic starting issue.
    1840 Post(s)
    The factory immobilser would not cause a total non start problem, it is run and cut. I would suspect the crank speed sensor, get a fault code read done. Didn't you have the (seventeen year old) car inspected and serviced it before driving half way across Europe?
  1. Please Help Offside front Wheel bearing ??--Noise
    By trevor simpson in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-05-2016, 06:31 PM
  2. Question 1999 B5 1.8 20v petrol estate front wheel noise
    By spacesave in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-12-2012, 07:21 PM
  3. Please Help Golf Mk 4 1999 starting issue Battery ?
    By gwh18 in forum Golf MK4 - 1999 - 2004
    Last Post: 20-02-2012, 08:22 PM
  4. Question Offside wheel knocking noise
    By markyb11 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-09-2009, 12:19 PM
  5. Audi Cabriolet 1999 Front Offside Indicator unit
    By sjw77 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 05-06-2009, 02:19 PM
