Thread: VW Polo 1.2 2008, 9N new KEY
  1. VW Polo 1.2 2008, 9N new KEY
    Sep 2017
    Edinburgh
    Hi. Just bought a really nice VW Polo and it came with only one basic key. It is a fixed blade with the small button which only operates a small bulb to see the lock. There is nothing else inside the plastic...just bulb, button battery.
    I need a SECOND KEY cut and bought a blank off web...thought I could then simply get locksmith to cut it. He says "needs programming" or useless.
    There is no sign of transducer or chip....anyone help please?
    CanI just get it cut only?
    Thanks!
  2. Re: VW Polo 1.2 2008, 9N new KEY
    May 2007
    17 Post(s)
    The locksmith is correct. Both keys will need programmed to the immobilizer.
    Jim.
  3. Re: VW Polo 1.2 2008, 9N new KEY
    Sep 2017
    Edinburgh
    Thanks Jim.
    Quotes seem to be
    1) VW dealers = £195 for one coded key
    2) Locksmith Auto specialist types (Cut and CODED etc)= £85 for 1 / £110 for 2
    3) Locksmith (NON-CODED) key cut = £20 (will only open door...will NOT work immobiliser).
    I have read that some people get 2 keys CUT ONLY (£40 for 2?) and take the immobiliser key and leave it in the car near ignition...this then allows the new cut keys to fully work?
    Also...others have taken the tiny "chip" out of the original key and TAPE IT under the ignition barrel...thereby ALL cut keys will fully function?
    Anyone done this and confirm successful?
    Thanks all!
  4. Re: VW Polo 1.2 2008, 9N new KEY
    May 2007
    17 Post(s)
    Quote Originally Posted by tomba59 View Post
    Yeah, that should work.
    I had to wire up a VW engine that had been fitted into a Suzuki Vitara a while back and that's how I got the engine running. By fitting the ring antenna (the coil around the ignition barrel) from the VW with the VW key placed inside the ring. I just cable tied it up behind the dash. So if you remove your ring antenna and place your original chipped key in the center of the ring, the non chipped keys should be able to start the engine.
  5. Re: VW Polo 1.2 2008, 9N new KEY
    1837 Post(s)
    I hate bodgery.......
  1. Polo 9n 1.4 TDI 2008 - sounds like a dog
    By saj121 in forum Polo - Derby - Lupo - Fox
    Last Post: 31-12-2015, 07:05 PM
  2. vw polo 2008 bluemotion
    By VW_Man in forum Body Work, Body Styling and Body Kits
    Last Post: 28-12-2014, 02:05 PM
  3. Question 2008 Polo cup holder broken...
    By Gillybean in forum Polo - Derby - Lupo - Fox
    Last Post: 31-03-2013, 12:17 AM
  4. Question 2008 Polo 1.4 TDI match MPG?
    By masserator in forum Polo - Derby - Lupo - Fox
    Last Post: 03-02-2009, 12:21 PM
  5. New 2008 Polo Question
    By Daveyk12 in forum Polo - Derby - Lupo - Fox
    Last Post: 15-04-2008, 08:19 AM
