Thread: Touran washers and rear wipe
  1. Post Touran washers and rear wipe
    Sep 2017
    Littlehampton
    Hello
    I wonder if anyone can assist with a problem on my wife's Touran. Its a 2006 model 2.0 TDi auto. The washers and rear wiper have stopped working. I have checked the fuse according to both the handbook and Haynes Manual and its ok. I have also checked the 404 relay's behind the dash and they function ok.
    Could the issue be the column mounted switch or is there something more obvious
    Any assistance would be grateful - as I've pulled what little hair I had left out over the problem
  2. Re: Touran washers and rear wipe
    May 2007
    17 Post(s)
    Do you hear the 404 relays clicking when you operate the front & rear washer? If they are clicking the next thing I would do is remove them and check the power supplies and earths on the terminals of the relay sockets. They are change over relays from what I can see on google so I'd guess terminal 4 (normally closed) will be the earth and terminal 5 (normally open) will be the 12V supply. Terminal 3 will be the output to the washer pump. Try connecting a voltmeter between terminals 4 & 5 on each relay socket and make sure you get 12V (ignition on).
    BTW, did you try swapping both relays over to see if that changes anything?
    Jim.
  1. Rear washers
    By fat controller in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-05-2015, 06:38 PM
  2. Avant rear wipe
    By pheelsteel in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 15-01-2013, 08:57 AM
  3. Please Help rear wash/wipe
    By martin59 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-10-2010, 11:58 AM
  4. Touran Headlamp Washers / Fuse
    By clydeman77 in forum Touran - Sharan - Caravelle
    Last Post: 20-03-2010, 07:36 PM
  5. Please Help Touran Headlight Washers
    By sayloday in forum Touran - Sharan - Caravelle
    Last Post: 04-12-2008, 11:28 PM
