Thread: audi a6 c6 glow plug and esp light
Results 1 to 1 of 1
  1. audi a6 c6 glow plug and esp light
    Jul 2012
    england
    i had an issue a few months ago where the glow plug light, esp, abs and electronic hand brake lights came on. I had the brake light switch replaced but the fault was still there. it turned out to be a broken cable. unfortunately the fault has resurfaced but only with the glow plug and esp light. the fault is more random now the I can drive over 100 miles before it comes on or it wont come on at all. I have noticed that sometimes when I have gotten out of the car the brake lights are still on. I've also had the car feeling like it wants to go into limp mode as in loosing power very briefly a couple of times then it stops. the whole fault is very very intermittent. Now when I turn the car on it will come up in the dash with esp off then come up with esp/asr on but the esp light is still on the dash and the esp button doesn't work. When the car is tested it says it the brake switch. I still don't know why this can cause the glow plugs light to flash
  1. Dpf/glow plug light + engine light audi a3 2.0 tdi
    By Rids in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 17-06-2014, 07:57 PM
  2. DPF/ glow plug light + engine light audi a3 2.0 tdi
    By Rids in forum Chat - Anything with wheels
    Last Post: 16-06-2014, 12:06 PM
  3. Help Needed audi 3.0 tdi glow plug light :(:(
    By quiggy28 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 18-03-2012, 03:36 PM
  4. Important My Audi a4 1.9tdi problem ESP light and glow plug system warning light
    By Ock00 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-02-2011, 01:33 AM
