Thread: Tune2air can't get it to work
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
  1. Tune2air can't get it to work
    Oct 2012
    East Yorkshire
    8 Post(s)
    Ok I have A6 C6 4F
    And have put an 4E0035785F music interface in with a Tune2air but it's not showing up on the mmi it says the tine2air connected to my iPhone 6
    Any help many thanks
    Audi A6 Avant 2011 C6 3.0Tdi Quattro Special Edition
  2. Re: Tune2air can't get it to work
    Oct 2012
    East Yorkshire
    8 Post(s)
    Really nobody wow ....
  3. Re: Tune2air can't get it to work
    Oct 2017
    GB
    When you press the media button do you have ami at the bottom of the list? If not then you will need vcds to activate the hidden green menu, in the hidden green menu you can activate the ami so the tune2air shows up, just retrofitted an ami myself with a tune2air and it works great
    Sent from my SM-G935F using Tapatalk
  4. Re: Tune2air can't get it to work
    Oct 2012
    East Yorkshire
    8 Post(s)
    Yes I have AMI but it's greyed out saying ami not connected
    Yes I have done the green menu
    Setting to 7/8
  5. Re: Tune2air can't get it to work
    Oct 2017
    GB
    Quote Originally Posted by Jimitop View Post
    Setting to 7/8
    I think it needs to be set to 5/8 not 7/8
  6. Re: Tune2air can't get it to work
    Oct 2012
    East Yorkshire
    8 Post(s)
    Quote Originally Posted by Furryhobn0b View Post
    I followed this from this site
    6. Enable AMI (Audi Music Interface) on MMI 3G (after fitting the hardware)
    [Select]
    [Control Module 5F]
    [Adaption - 10]
    Channel 6
    New Value = 1
    Restart MMI (Hold in SETUP + Centre MMI Knob + Upper Right Inner Key]
    Go into hidden menu, hold in CAR + SETUP ... WARNING DO NOT CHANGE ANY VALUES YOU DON'T KNOW OR ELSE BAD BAD THINGS MAY HAPPEN
    Diagnosis -> Settings -> Audi Music Interface (AMI) set to 7/8
    Press RETURN and come out of the hidden menu.
    Press MEDIA, Source and test the AMI.
  7. Re: Tune2air can't get it to work
    Oct 2017
    GB
    [Select]
    [Control Module 5F]
    [Adaption - 10]
    Channel 6
    New Value = 1
    Mine is definitely set to 5/8, I'll get a pic for you later, go and quickly change it to 5/8 and see if it starts working for you
  8. Re: Tune2air can't get it to work
    Oct 2017
    GB
    Just took a quick photo
  9. Re: Tune2air can't get it to work
    Oct 2012
    East Yorkshire
    8 Post(s)
    Mine in 5/8
  10. Re: Tune2air can't get it to work
    Oct 2017
    GB
    Mine in 5/8
    Just out of curiosity you have turned Bluetooth on your device? I think it shows no device connected until you are actually connected to the tune2air with your phone, what version mmi are you?
  1. Visseo Tune2Air
    By Norrington21 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-11-2014, 04:50 PM
  2. What do these do and how do they work?
    By stpeattg in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-09-2012, 10:25 PM
  3. Parking Sensors work then don't work
    By fabusy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-02-2010, 10:03 PM
  4. V5, how does it work?
    By saunders1587 in forum Chat - Anything with wheels
    Last Post: 04-05-2008, 03:07 PM
  5. Ipod and cd changer work around....will this work?
    Last Post: 10-07-2007, 03:47 PM
