Thread: Audi A3 1.8T 98 ABS light problem
  1. Audi A3 1.8T 98 ABS light problem
    Sep 2017
    Norway
    I have a ABS problem at my audi a3 1.8t 98.
    My ABS-lamp light sometimes and sometimes not.
    Its happend when I start the car after a while. But if I stop it and start again, it still lights up. But after driving a few meters it turns off. (sometimes I have to drive it hard before it leaves). Then it will not be left until the car has been turned off for a little while.
    Measured the battery after it has stood for a while and is 12.2 volts, so I'm sure it's not going to do anything about it?
    Do anyone have that problem before?
  2. Re: Audi A3 1.8T 98 ABS light problem
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Check all your wheel sensors and reluctor rings for dirt and damage, you can check the sensors for output by connecting a volt meter and turning the hub to see if the sensor generates a small voltage. check the wiring connectors at the sensors, your intermeiient fault sounds like a bad connection somewhere. if all ok check the ABS unit, these have pressure switch, solenoid valves and a pump that can fail and a circuit board that can get cracked solder joints, you can send the abs unit away for repairs. I don't know if there is much diagnostics you can plug in to pinpoint the problem on a '98. Maybe VCDS would pick something up though.
  3. Re: Audi A3 1.8T 98 ABS light problem
    Nov 2017
    Scotland
    25 Post(s)
    vagcom/VCDS will give the exact fault code--internal pressure switch on MK60 abs pumps is conman fault- but it may just be a case of doing a basic setting on the abs module !! really need a scan and fault codes !!!
  1. Audi A6 side light problem - HELP
    By blacky010_10 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-10-2012, 11:59 AM
  2. Important My Audi a4 1.9tdi problem ESP light and glow plug system warning light
    By Ock00 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-02-2011, 01:33 AM
  3. Please Help Audi a3 low oil pressure light problem
    By Paul70 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 21-08-2010, 12:31 PM
  4. Audi A3 1.8T Rear light problem
    By Charlie15 in forum Archive posts
    Last Post: 17-01-2007, 11:10 AM
  5. Audi A4 Brake light problem
    By agriffiths in forum Archive posts
    Last Post: 22-12-2006, 02:10 PM
